alternator?
Old Jul 21, 2006 | 08:16 PM
painterman52's Avatar
painterman52
Default alternator?
What would cause my lights to go bright then dim. I just noticed the inside light is much brighter at idle than at higher rpm. And they pulsate some.
Old Jul 21, 2006 | 08:27 PM
...Roger...'s Avatar
...Roger...
Is this a new problem?
Old Jul 22, 2006 | 07:14 AM
kb2fzq's Avatar
kb2fzq
Sounds like a voltage regulator problem to me.....
Old Jul 22, 2006 | 08:26 AM
painterman52
Its not a new problem. there were always bigger problems. now I`m getting down to details.
Old Jul 22, 2006 | 08:36 AM
...Roger...
like KB2 says probably regulator-take alt off and have checked for free at autozone to rule that out
Old Jul 22, 2006 | 09:36 AM
SIXFOOTER's Avatar
SIXFOOTER
If you have access to a voltmeter with the needle instead of digital, connect it to the backof the alternator and you may be able o see the variations in the voltage. I agree with the other guys, regulator probly partially dead. There is a six pack of diodes in there and one or 2 pairs might have opened up. It will still work (sortof) but that pulsing at idle is what you would see.
Old Jul 22, 2006 | 09:00 PM
painterman52
I replaced the alternator, everything is good. Thanks for the advice.
To alternator?
