Need AC help
The engine temperature never get hot but the darn AC is driving me crazy.
I have posted before on this but get all kinds of advise on cooling the engine but that is never a problem
You definitely could be overcharged. This would increase the high pressure side to the point where too much refrigerant is entering the evaporator coil--flooding the evaporator--and returning liquid refrigerant back to the compressor. Which compressors do not like at all--which may explain your parade of replacement compressors.
What type of refrigerant are you using?
How much did you charge?
What type of flexible refrigerant lines are you using (stock or replacement?)
Any under drive pulley's?
What type of orifice tube? The variable ones now available are just **** for stop & go traffic.
Neal
What type of refrigerant are you using?R12
How much did you charge?Not sure had AC shop charge system over here we use AC year round so there are many shops.What type of flexible refrigerant lines are you using (stock or replacement?)Some stock some braided Stainless steel.
Any under drive pulley's?Stock pulleys on engine and on the sanden the one that comes with it.
What type of orifice tube? The variable ones now available are just **** for stop & go traffic. Sorry dont know what this part is???
[quote]Dean does your car have an idle solenoid? If so you may look at it, if not do you have a set of service gauges to see what’s going on with the system when it starts acting up? The possibility of liquid getting back to the comp is not likely, it would only take a very little liquid to destroy the comp, one cause of liquid getting to the comp would be a very cold day and the system being way over charged. I am assuming that you think it's the A/C because when it starts acting up you can turn the A/C off and it idles fine. How are the extra fans wired? If they are wired to run with the A/C maybe the extra load on the electrical system along with the A/C could be taxing the engine at idle, you may have the electrical system (alt)checked out.
Neal[quote]
I had this problem long before I added the extra fans. No I don't have an idle solenoid but I run a high idle with AC off 900 RPM, when it acts up and I turn off the AC it idles fine and the binding feeling stops.
Neal
Neal
You can't even make educated guesses without knowing the pressures and most of the answers below.
At approx 1500 rpm, with a/c function switch set at normal, temp control to "cold" (not recirculating cockpit air):
-measure ambient air temp approx 2" in front of condenser
-measure center dash vent air temp with blower on high
-measure temp at top of dash
-high side pressure
-low side pressure
Did they remove and flush evaporator after each compressor failure?
Was the rest of the system flushed?
Was the orifice tube replaced?
What no. oriface or color is in it?
Was the drier/accum replaced?
What model Sanden did they put in?
What type and viscosity of oil was put in?
What amount of oil was put in?
Can you post a pic of the condenser mounted on the rad support?
Neal
Did they remove and flush evaporator after each compressor failure?No they evacuated onlyWas the rest of the system flushed?No they evacuated only
Was the orifice tube replaced?Still don't know what that is?????
What no. oriface or color is in it?Still don't know what that is?????
Was the drier/accum replaced?Everything was replaced to new parts
What model Sanden did they put in?508
What type and viscosity of oil was put in?Don't know
What amount of oil was put in?Also don't know
Can you post a pic of the condenser mounted on the rad support This is difficult must remove hood to take the picture. But it is the original radiator brackets and condenser
As I mentioned above I will try to get some readings in the next couple of days. Also the AC runs cold and engine runs good when the car is moving. The problems happens when idling in stop conditions.
Just for the fun of it try to get some pics without removing the hood. Maybe you can just hold the camera and guess at aiming it.
Need the info, can't guess a diagnosis.
Just print out the questions and have the shop give you the answers if that is possible. Or buy a cheap set of guages. You can get everything else over there dirt cheap; fake watches etc. LOL
The orifice tub is a calculated metering device that causes the medium temp, high pressure liquid refrigerant to drop to a low pressure gas, this change in phase causes the refrigerant to give up its heat and causes the cooling effect you feel at the evaporator. It’s a small device that is in the inlet line to the evaporator, there are two inset areas in the line right at the line connection on the inlet of the evaporator, and these insets hold the orifice tub in place. Because the orifice is so small there is a screen on the inlet of the orifice so it does not get plugged easily. Just type GM orifice tub into Goggle and you can get a pic of one.
Neal
When the shop flushed my system he was amazed to find almost a quart of oil in the condensor...almost 1/2 of the condensor was filled with oil. That's way too much oil, which means that very little freon was in the system. My guess is that the shop barely got 2 or 2-1/2 lbs of freon into your system while it should have accepted like 3 or 3-1/4. Have them flush the system...my shop mechanic said he spent almost a full 30 minutes pouring A/C system flush fluid through the condensor alone.
When the shop flushed my system he was amazed to find almost a quart of oil in the condenser...almost 1/2 of the condenser was filled with oil. That's way too much oil, which means that very little freon was in the system. My guess is that the shop barely got 2 or 2-1/2 lbs of freon into your system while it should have accepted like 3 or 3-1/4. Have them flush the system...my shop mechanic said he spent almost a full 30 minutes pouring A/C system flush fluid through the condensor alone.
I will try to pull the condenser to have it flushed out.
