Radio problem
Old Jul 24, 2006 | 02:40 PM
Travis Sieve's Avatar
Travis Sieve
6th Gear
Default Radio problem
I turned the radio on my 74 stingray off and now it will not come back on. When I turn the ignition key the radio lights up but then the light fades quickly and and radio will not turn on. Any help would be great.
Old Jul 24, 2006 | 03:38 PM
Boofers's Avatar
Boofers
If you are not blowing any fuses and the radio is getting power then the radio is probably broken.
Old Jul 24, 2006 | 11:05 PM
BLUSHRK's Avatar
BLUSHRK
Try looking at the fuses that come off the back of the radio itself. Red wire usually has one and also the yellow. If the red fuse(ignition) is bad and the yellow fuse is good(batt) then the radio will light up for a sec then go dark. At least my Kenwoods would do that back in the day...worth a look...They are usually very low amperage fuses and blow rather easily.
To Radio problem
