wire gauge by amperage
thanks
-jeff
14 ga - 15 amp
12 ga - 20 amp
10 ga - 30 amp
I'll have to let the automotive experts reply on this un. The above is probably a bit much on the conservative side for an automobile.
14 ga - 15 amp
12 ga - 20 amp
10 ga - 30 amp
As previously stated, residental/comercial wiring is #10=30amps. Solid or stranded is the same. I have noted that auto wiring seems to be smaller than expected sometimes. Check your connections. Loose or poor connections will cause excess heat also.
http://www.powerstream.com/Wire_Size.htm
Code books just don't specify the guage of the wire and current load. The length of the wire plays a vital role into the proper gauge of wire that is needed.
anyway, i'll rewire it with 10G this weekend and hope for the best with a 25A fuse.
Ah...electricity...what a shocking feature.
The gauge of the wire is a measure of the diameter of the wire. Nearly all of the wire in use today is made of copper, including our vettes and any wire you will get for replacement unless it's some special wire that you don't want. The gauge of a wire is not the only determining factor for the current that can flow through it...length is also a factor because the limiting factor is the resistance of the wire. The resistance of a wire is Rho *L/A which is the resistivity (Rho) times the length divided by the cross-sectional area of the wire. The cross-sectional area is Pi * R^2 which is 3.1416 times the square of the wire's radius. The resistivity of copper is about 55 * 10^-9 Ohms * ft.
The resistance of a copper wire of a certain gage is usually available as an Ohms per foot specification…I notice that the table on the link above is in Ohms per 1000 feet.
Now...what we are REALLY concerned about here is not just how much current is passing through a wire, but how much resistance is in the wire when that current is passing through it. This is because the wire will produce heat in the range of R*I^2 which is the resistance times the square of the current. If we increase the current then it will increase the heat produced by the square of the current. And, if we increase the resistance (longer wire or smaller gage wire) then this will also increase the heat.
Based on the chart and experience I would say that the wire you can use is a 16 gage as long as it is not any longer than 5 feet. But, since you are saying that it's getting too hot with a 14 then it sounds like your wire is longer than 5 feet. If a 5 foot 16 gage wire carries 25 amps then it will create 12.3 Watts of heat. This appears to be the ball-park peak wattage for the chart in the previous post. I won’t know exactly if this is OK unless I can see the manufacturer specs for the wire to see how much heat it can dissipate. Personally, I would not want to see any more than 5 Watts of heat coming from a wire.
If you want to play around with my spreadsheet then you can download it from here (You will have to change the extension to xls because that server always turns file extensions to .doc for some reason):
Wire Heat Calculator
To use...change the highlighted parameters for length and amps and then look down the right column to see what the wattage is for the heat generated until you find something that will generate less than 15 watts and you should be fine...again this is just based on that chart.
http://www.geocities.com/CapeCanaveral/Lab/9643/awg.htm
i pulled apart all of the wiring, and it appears that the temp sensing relay is all wired up correctly (albeit such that the fan comes on at what appears to be 100F...it's a desert so who cares?), however, the leads running to the fan are smaller (spade connected) after the original leads run out...as in 12 gauge out of the relay, switched to 14/16 ga after. when the fan runs, those connections getvery hot (as expected), but i also feel significant warmth from the relay's leads (the 12 ga portion of the setup), and most significantly from the fuse connection (flat type). will the restriction downstream cause heat upstream? or do i need to rewire with a new relay?
if option 2, please point me to such a relay.
Phil
