its comming along
Old Jul 24, 2006 | 09:44 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default its comming along
My wife gave my unfettered access to the mastercard
My plan:
Shortblock:
SCAT 9000 crank with 3.48 stroke with the 1 RMS
SCAT 4340 I-beam rods with a pressed pin
Probe 21cc dish pison(ceramic coated crowns)
billet mains
ARP bolts
Heads+valvetrain:
the heads are the superflow 190cc heads that have brutally attacked by my and my craftsman grinder
(with ceramic coated chambers and exhaust ports)
ferrea comp 6000 valves
GMPP dual valve springs 140# closed pressure 325# average pressure
GMPP aluminum retainers(matching spring)
GMPP valve locks
AFR hydrarev kit
OEM roller lifters
LPE 213/219 cam with .462/.471 and a 112 LSA
SA Gear timing chain
Catpep 1.5 shaft rockers
intake+fuel:
the intake is a weiand X-celerator low profile single plane
Holley 4779-6 w/ 4-corner idle(currently trying to modify gasket residue is giving me and every solvent in the world a fight)
Racepumps EFI fuel pump
Racepumps boost referenced fuel pressure regulator
Exhaust:
Ramhorns
2.25" remote mount pipe
Grand national turbos w/ stock elbow and intergal wastegates(will modify the arm for adjustable boost) above the frame rail
(2.25" pipe is a big U starting at the ramhorn and going to the other side of the frame rail where the turbos sit)
2.5" tail-pipe with dynomax ultra flows
Intercooler is on the list of stuff to pick out
as is a carb hat(xstream velocity probably)
Cooling+oil:
Howard Stewart stage 3 water pump
Titan speed engineering sportsman wetsump pump(HA HA my oil pump doesnt cavitate neener neener neener)
there will be an oil cooler, and fuel cooler, and a big aluminum radiator(31x19)
shiney chrome 5-quart oil pan
For those that actually read all this, thank you, and comment. I have tried to make it fun, as people tell me I always sound angry on the internet. Comments, flames, threats against my mother?
Oh yeah for your viewing pleasure AUTOMOTIVE ****, see young engines with no covers only 9.95 a minute
Old Jul 24, 2006 | 10:06 PM
vettecrazy88's Avatar
vettecrazy88
I am soooooo jealous.
Unfettered access to credit cards?
Will you adopt me?
Engine looks sweet by the way.
Old Jul 25, 2006 | 01:03 AM
sperkins's Avatar
sperkins
And she let you build it in the house!!!
Where did you find her?!
Old Jul 25, 2006 | 02:47 AM
babylonvette's Avatar
babylonvette
Default its coming along
does she have a sister i have to pay cash or money order to hide the prices from my wife
Old Jul 25, 2006 | 03:37 AM
82MDVette's Avatar
82MDVette
Would you mind if I gave you a "small" list of parts I am in need of to finish the '82.
She wouldn't even notice
Old Jul 25, 2006 | 06:38 AM
Guru_4_hire
Cruise-In V Veteran
I have a whole bunch of stuff I am willing to let go cheap.
I met her in DC
and she has a 5 year old brother
and yes she let me build it in the house, though I did get the stick eye for trying to get holley gasket crud off of my holley 750 on the patio table.
Old Jul 25, 2006 | 08:03 AM
Bangkok Dean's Avatar
Bangkok Dean
Ok whats the catch here
Old Jul 25, 2006 | 08:09 AM
mrvette's Avatar
mrvette
heheeh......I USED to do that too....in the kitchen.....between marriages....
I wouldn't do it to this kitchen now that it's done, anyway....too damn much work there....
that engine sitting in that closet/nook reminds me of rebuilding a small sailboat while living in a hi rise....the stench of fiberglass curing about knocked the entire building outta existance....seems the boat was not far from a fresh air intake....oops!!!
Old Jul 25, 2006 | 08:23 PM
Guru_4_hire
Cruise-In V Veteran
My wife is nice, and I confine my toys to the basement.
Old Jul 25, 2006 | 09:17 PM
vettecrazy88
Sounds to me like you've got 2 keepers.
Wife and car.
Good luck!!
To its comming along
