Headlight switch?
Old Jul 25, 2006 | 09:41 AM
busterpelvis's Avatar
busterpelvis
Default Headlight switch?
Suddenly lost amp gauge ,temp gauge,low fuel light ,& gauge lights.
Battery light is on.
This all happened one night when i turned on headlights.
Could this be all connected to headlight switch, or is circuit bd bad?
TIA
Old Jul 25, 2006 | 01:38 PM
SIXFOOTER's Avatar
SIXFOOTER
sounds like more than one problem, Battery light comes on when the diodes in the regulator short, gives a path to ground. The rest sounds like circuit board on the insturement cluster. Check connections back there
Old Jul 25, 2006 | 02:24 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Certainly more than just a headlight switch.
To Headlight switch?
