corvette82
Old Jul 25, 2006 | 09:49 AM
warrior2291's Avatar
warrior2291
Default corvette82
I have a question, I own a 1982 corvette collector edition. I want to change the alternator on it. I have noticed them at different prices and I also noticed that they have 100 amp, 85 amp, and 70 amp. Would it make a difference if I went to a higher amp alternator? do I need to change anything else to do this? would it hurt anything if I did?
Old Jul 25, 2006 | 10:47 AM
rizman99's Avatar
rizman99
If you can afford the 100 amp go for it.
No other changes should be needed....
Old Jul 25, 2006 | 12:50 PM
82X-FireVette's Avatar
82X-FireVette
The '82 came with a 70 amp alternator. You should be able to upgrade it but make sure the wiring is compatible.
Old Jul 25, 2006 | 01:32 PM
SIXFOOTER's Avatar
SIXFOOTER
I agree, no other changes needed, its just a bigger bucket of amps and it will not drive anything harder than the old one, provided everything else is (was) working correctly
Old Jul 25, 2006 | 02:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Are you concerned with originality? Is your alternator the original? If numbers matter, you might want to consider having your original (it's dated) rebuilt.
Old Jul 26, 2006 | 11:31 PM
MN-Brent's Avatar
MN-Brent
The bigger alternator will require the larger belt option.
53.5inch for non 70Amp alternator
54 inch for 70Amp+ alternator.
The difference is trying to get the belt on with the larger alternator. If you dont have the longer belt, you cant adjust the alternator in close enough to get it over the other pulleys during install.
You'll end up having to put the V-belt on the alternator while it is loose (not positioned with any bolts yet). You then have to balance the alternator with belt on and try to install the bolts at the same time. A huge PITA
As they say "Ask me how I know!!!"
Brent...
Old Jul 28, 2006 | 09:26 AM
warrior2291
Default corvette82
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEBI%3AIT
click on this link this is the one I am going with I dont think I will have any trouble with this one
warrior2291
Default 82 corvette
No not worried about that
Old Jul 28, 2006 | 09:38 AM
kdlp's Avatar
kdlp
Regarding the E-bay alternator... I'm always a little suspicious of the low-cost alternators. I know there are less than quality parts available on rebuilds, etc. and can't help but wonder if those parts aren't used in the cheapo alternators.
As you know, alternators are heavy and shipping those things all over can quickly eat up the difference between the cheapo unit and the quality unit that you'll get years and years of use from.
If you want to talk (email) a guy who builds the good stuff with quality parts you might try Rush Power Systems (http://www.rushpowersystems.com/)
After talking with Darren I'm convinced that he doesn't want to see any of his stuff coming back. It's probably a bit more expensive than the cheapo.... but in the long run....
Good Luck,
kdlp
Old Jul 28, 2006 | 10:16 AM
warrior2291
Default corvette82
thank you very much i am on the phone with him now
To corvette82
