Quadrajet Help...please
Old Jul 25, 2006 | 11:35 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Quadrajet Help...please
I am doing a major tune up on my buddy's '70 454 matching numbers coupe....shielded wires are old and brittle, old plugs, points and a chinese made coils. Replaced all of the above. Car has a reman carb on it now and is running extremely rich.....like clouds of black smoke when you goose it.
So he buys a Champion Brand reman carb from AutoZone......same thing.....and the car actually runs woose than I before started dumping alot of gas into the intake..
Sooooo I put my LARS rebuilt Q-Jet off my '72 350 Vert and the car runs PERFECT.....Thank you Lars
I just don't get it ...how hard is it to rebuild a carb...especially if you are a company that does it everyday...oh yeah these carbs are supposed to be tested...right
Is Lars still on a break from building carbs????
If so, anyone know where he can get a good carb???
Mark
Old Jul 25, 2006 | 11:42 PM
Bob Onit's Avatar
Bob Onit
I tried a Champion rebuilt
Same thing
Super rich.. I believe they do this to protect their A$$ from burning up engines from being too lean
Old Jul 25, 2006 | 11:44 PM
noonie's Avatar
noonie
Not that big a deal. Probably got bounced around a lot in shipping/ handling and the float is stuck or jammed or out of whack.
Take the carb apart and check it out. No replacements are just bolt on. Did the idle adj screws do anything?
Old Jul 25, 2006 | 11:49 PM
Bob Onit's Avatar
Bob Onit
The one I bought was a mess
Mis- matched parts ,sloppy bushings re-drilled, oversized vacuum ports.... total garbage
Never even bothered to take the air horn off.... just took it back and got my refund
Old Jul 25, 2006 | 11:56 PM
mbeeman350's Avatar
mbeeman350
I took the carb apart before the instal...no numbers on the rods or Jets....thought that was strange float was good Idle screws had little effect since there is so much gas being dumped into the intake.
Oddly enough I checked the ORIGINAL application (researching the numbers stamped on the side)and this carb was originally for a 70 GMC/Chevy California truck with a 350.
And this what they supply for ALL GM V8s with a 4 BL ,reguardless if it a Nova with a 350 or a Goat with a 455, 454 Vette, 454 SS Chevelle etc.
Mark
Old Jul 26, 2006 | 12:04 AM
Bob Onit's Avatar
Bob Onit
And this what they supply for ALL GM V8s with a 4 BL ,reguardless if it a Nova with a 350 or a Goat with a 455, 454 Vette, $54 Chevelle etc.
Mark
Does it look like a truck carb?
Also if you have some spare jets and rods try leaning it out.. It might work
Old Jul 26, 2006 | 12:22 AM
mbeeman350's Avatar
mbeeman350
Not sure what a truck carb looks like!!!
The new carb matches the POS reman we just took off.
Don't know what the original 70 BB 454 4 speed carb looks like...
Old Jul 26, 2006 | 12:51 AM
Chris Farrer's Avatar
Chris Farrer
I had a carby professionally reconditioned and the thing would not stop flooding. Turns out when it was originally shipped dry, a small hole must have worn in the brass float. When fitted the float filled up with fuel causing it to sink and flood the carby. She runs like a dream now.
Old Jul 26, 2006 | 01:00 AM
BigBlockk's Avatar
BigBlockk
It is easy to rebuild a carburetor but if the calibration is wrong it's wrong. Rebuilding the carburetor is not going to change that because there is a difference between rebuilding and tuning. Rebuilding is simply cleaning and replacing worn parts. You can not tune a carburetor with a rebuild kit.
BigBlockk
Later.....
Old Jul 26, 2006 | 02:19 PM
mbeeman350's Avatar
mbeeman350
BigBlockk
Later.....
Thanks BB..that's it exactly.....I learned a good lesson on rebult carbs. The builders try to cover too many apllications with just one carb.
Going to return the reman carb to AZ
In the meantime we found a carb rebuilder in St Pete to build a carb to factory specs for this car. He had all the specs, to be sure we gave them to him again, the original rod and jet sizes, spring etc.. for this car...
Well see....carb will be here Thursday...will post results...
Mark
Old Jul 26, 2006 | 03:26 PM
BigBlockk's Avatar
BigBlockk
Mark
For those who are not comfortable doing it themselves this is a very smart move. So many more would be happy with their rebuilds if they would just put some research into it. Even if someone has to get the jets and rods themselves. As a matter of fact that is a very good recommendation.
WHEN YOU HAVE A CARBURETOR TO REBUILD, GET THE REBUILD KIT (ECHLIN), JET/ROD COMBO FOR YOUR CARBURETOR, NEW FLOAT AND NEW CHOKE PULLOFF AND TAKE ALL OF IT TO YOUR RE BUILDER. MAKE SURE THEY UNDERSTAND THAT THE SETUP SHOULD BE IN THE CARBURETOR WHEN YOU COME BACK TO PICK IT UP.
I an not shouting I just want everyone to take note.
Mark, this is a very good idea.
BigBlockk
Later.....
Old Jul 26, 2006 | 03:35 PM
mbeeman350's Avatar
mbeeman350
I have built and tuned a lot of Holleys over the years but ran away from the Q-Jets. Now after doing some research and having Lars do my mine, as well as reading Lars Paper. I would tackle the next one.
In this case its a buddys car, parked in my Vette's space, in my garage...he doesnt want to wait on ordering parts, just got the car and wants to drive it....right now!!!
Otherwise I would have gone throug his old carb, ordered parts etc. This is an intack very nice BB coupe, 70, EXCEPT the alternator and carb!!!
Mark
Old Jul 26, 2006 | 03:43 PM
Bob Onit's Avatar
Bob Onit
Sorry for the late reply
Truck QJ's look a little different from the top
Heres a truck QJ
And heres a passenger car QJ
Notice the difference in the position where the fuel is introduced
Hope this helps
Old Jul 26, 2006 | 06:20 PM
Kalway's Avatar
Kalway
Isn't the top one an M4M and the bottom one a 4MV?
Old Jul 26, 2006 | 07:23 PM
corvette_maniac's Avatar
corvette_maniac
Everyone knows that the bottom one is an 4MV. You can always tell them by the blue needle nose pliers.
Old Jul 26, 2006 | 08:08 PM
Kalway's Avatar
Kalway
Old Jul 26, 2006 | 09:40 PM
Bob Onit's Avatar
Bob Onit
Exactly
The top is a 1978 truck carb and the bottom is a 1973 4MV
Watch out Kal, or I'll knock you off your tricycle
ps: I only have 2 hands, what else could I have used to hold the choke open for the pic.?
Nope, not that, the bench was too low
To Quadrajet Help...please
Old Jul 26, 2006 | 10:08 PM
corvette_maniac
Exactly
Some red ones....? LOL
Old Jul 26, 2006 | 10:59 PM
Kalway's Avatar
Kalway
Exactly
The q-jet design changed quite a bit around '76, I believe. That was the introduction of the 795cfm M4M q-jet (17xxxxxx). Doesn't mean it's a truck carb, it's just a different model.
Old Jul 26, 2006 | 11:09 PM
Bob Onit's Avatar
Bob Onit
maybe so
Im just going by what a builder told me
Ill plow through Doug Roe's book when I get a chance
