need engine rebuild advice
The one thing i would like is a little more power. not anything crazy.
would like at least 300hp at the wheels.
what advice would you give me with the above details. i do not want to put on headers, as they would compromise my collector plates i have now.
of course, i want to spend as little $ as possible, but since i will be rebuilding it, it would make sense to do any upgrades at this time.
any advice greatly appreciated!
I would stay with that cam (but new if it's still avail) but add induction and exhaust to the equations.
If you want a stroker, that cam isn't the right one for a stroker but ther''s lots of choices out there. Use aluminum heads, 2.05 stainless valves and have the intake port matched to the heads.
Make sure you get it balanced no matter what. Use a completely forged bottom end if you can afford it.
Or just get a zz383 from the dealer and have some fun!
At today's machine shop prices, I believe it's more cost effective to buy good aftermarket rods with good hardware , rather than paying to check the old rods for cracks and flaws, twist , and then resized with good ARP rod bolts , which also shortens the rod length.
As for heads , if $$ are very tight , Summit has good quality cast iron heads available for about the cost of rebuilding your originals , or you might want to consider using the newer Vortec heads with a Performer or Performer RPM intake , which would be an improvement over the original intake in either case.
Most important is your selection of a competent and honest machinist , who will actually do the work he's paid to do , since you indicate that you will have to rely on him to evaluate , measure , machine , and assemble the motor. Ask around at the local cruise nights in your area for recommendations - ask enough people , and the best shop should reveal itself by satisfied customer recommendations. Then go and talk to the machinist at his place of business , and note the cleanliness and organization of his shop , and determine if he's interested in building what you want built , or wants you to buy what he would rather build.
On that same note , I've noticed over many years that the guys who brag about themselves the most usually don't produce anything worth bragging about.
Keep us posted on your progress.
The heads are also a great place to pick up power for low bucks. You save the cost of rebuilding the heads and you get all new parts + power too. The iron heads that summit sells are probably the best bargain for this application. You can keep the rest stock. Curve the distributor too.
That "962" cam is still available from several sources. I installed that one in my car with upgraded heads and it performs well with plenty of high RPM range available. If you combine these upgrades with the stroker crank you will get a relaible, easy to live with torque monster. Keep the C/R around 10.4 or so and you can still run the pump gas with that cam.
-Mark.
I'd keep the original block, yours may not even need a overbore (just keep it for later resale value) and put a new block with a stroker rotating assembly under the hood
... probably the cheapest way to go (HP for the $$$)
