Primer question
Old Jul 26, 2006 | 11:41 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default Primer question
I'm still scraping the red paint off my car The razor blade method works fine but it takes longer than I thought.... well, I started two other projects at the same time...
Anyways..... I can get a good deal on DuPont paint - what primer should I order ? I can't find anything on their website, they only list primers for 'metal' and 'plastic' exteriors in their automitive section....
TIA
Old Jul 26, 2006 | 02:20 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I searched the archives and it appears that PPG DPLF epoxy primer is what most members recommend. Does anybody know the DuPont equivalent ???
Old Jul 26, 2006 | 03:03 PM
vettfixr's Avatar
vettfixr
Here's a good forum to ask your questions. They're good people there and they'll give you a lot of help.
www.autobodystore.com
Old Jul 26, 2006 | 03:21 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
thanks, that page is bookmarked
Old Jul 26, 2006 | 10:59 PM
bondoboy's Avatar
bondoboy
Sand the body and do all of the body work. You will want to use a urethane fill primer. Dupont has uro and ppg has k36. Both work very nice. Using epoxy first is crap. It is a waste of money and it's not meant to be sanded. Epoxy is generally used as a sealer.
Old Jul 26, 2006 | 11:33 PM
Jclgodale3's Avatar
Jclgodale3
I used the K38 high build, block sanded and a light coat of white DPLF primer/sealer before the base color went on.
To Primer question
