what are the symptoms of an out of balance driveshaft? I have replaced all U joints halft shafts also but still have a weird spinning sound on the slightest of acceleration. In neutral,rolling it does not do it. any help?thanks
You would feel a vibration if the drive shaft imbalance was bad enough.
It's hard to diagnose a "weird spinning sound" via the internet but I suppose it could be a worn out wheel bearing, loose engine accessory belt, something odd happening inside of the transmission, squeeky brake pads???
Provide more information if you can. Someone will come up with the right answer.
