headers and heat risers
Old Jul 27, 2006 | 05:02 PM
NOCKOUT's Avatar
NOCKOUT
Default headers and heat risers
I bought some headers for my 73 L48 that I have been working on. When I removed the exhaust manifolds I noticed that there was a heat riser valve in line on the passenger side. Does anyone know if I need to put in a heat riser valve in line with the headers I am putting on?
Old Jul 27, 2006 | 05:15 PM
Scott Marzahl's Avatar
Scott Marzahl
No, installing a restrictive heat riser would defeat the purpose of you installing free flowing headers.
Old Jul 28, 2006 | 03:34 PM
stingr69's Avatar
stingr69
The heat riser goes away when you install headers. That is part of the EFE system that is designed to warm up the engine quickly after a cold start. You can now block the heat riser passage at the intake manifold (as long as you run an aluminum intake). The warm up will take a few minutes longer this way but that is part of the sacrifice of running headers.
If you have an iron intake, you probably won't be thrilled with a blocked heat riser. The engine will take a LONG time to warm up fully.
-Mark.
To headers and heat risers
