Questions about quadrajet applications
Old Jul 27, 2006 | 07:54 PM
1mollyd's Avatar
1mollyd
Default Questions about quadrajet applications
I searched the archives and I can't seem to find the answers to my questions.
I looking for a quadrajet to put on my '69 350(stock build) with 4 speed.
I'm not real concerned with date codes as this is a NOM car.
I was looking a a quad off of an 1980 vette and wonder is there are any problems running it on the older engine?
Also if a quad is stamped with a 6 indicating it came off a car with an automatic, are there any issues running it on a manual? What's the difference in the carbs between manual and automatic?
TIA
Dave
Old Jul 27, 2006 | 09:02 PM
Kalway's Avatar
Kalway
First off I'll say to get a q-jet from a '75 or earlier Vette. Parts are easier to come by for those. Second, a q-jet is NEVER plug and play they must all be tuned for every car they're put on. Tuning it isn't really that hard, either. A simple jet and rod change is usually all it takes to tune it in right.
Old Jul 27, 2006 | 09:48 PM
7T9Shark's Avatar
7T9Shark
An '80 Q-Jet should bolt right on. The only difference is that you'll need to plug the vacuum source for the automatic modulator, and you'll have an extra stud on the linkage where the kickdown cable normally attaches, which you can remove.
As far as tuning goes, you may have to do some tweaking, but perhaps not. When I bumped the HP of my mill, all I had to do was richen up the idle jets to match the cam and compression changes.
Not a diffcult prospect. I'd do it in a heartbeat.
Old Jul 27, 2006 | 10:06 PM
Bob Onit's Avatar
Bob Onit
As far as I know it would be pre 75, so a 75 is a no go.
I have a ton of parts here and its amazing how many changes they have gone through from 66 to 74.
I would try to get as close to a 69 as possible
I could post pics of the differences from a 71 to 73.. theres alot to consider
I would certainly stay away from anything later than 1974
Old Jul 28, 2006 | 09:39 AM
1mollyd's Avatar
1mollyd
Bob Onit,
If you would post some pics that would be great!
I have located a Quadrajet from a 69 350/350 that I was looking at, however I was wanting to go with an electric choke setup, is there a conversion for this?
Thanks.
Dave
Old Jul 28, 2006 | 09:47 AM
Bob Onit's Avatar
Bob Onit
Originally Posted by 1mollyd
Bob Onit,
Thanks.
Dave
Yes I can but I have to wait till I get home from work to post them
Whats wrong with the stock divorced choke?
They work great.
There are conversion kits, not sure about 69 though
Theyre also about $50
Old Jul 28, 2006 | 11:02 AM
1mollyd's Avatar
1mollyd
They work great.
I'm changing to a Performer manifold with the exhaust crossover blocked.
I've heard that this will cause the choke to take a lot longer to pull off. No?
Thanks.
Dave
Old Jul 28, 2006 | 01:28 PM
Bob Onit's Avatar
Bob Onit
Thanks.
Dave
I dont know how much longer but, yes,
I have an Edelbrock Performer and it still works fine plus I dont drive my car after october, maybe early november so It doesnt really matter to me
Old Jul 28, 2006 | 02:29 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Ditto...Performer 2101 and divorced choke works like a champ....My exhaust crossover is open however...
Old Jul 28, 2006 | 05:36 PM
Boofers's Avatar
Boofers
My exhaust crossover is blocked and I converted to electric using this Edelbrock electric choke conversion kit. Fit on my stock QJet no problem. This is the third year I have had it and no problems. I powered it using the windshield wiper +hot wire.
www.summitracing.com
Part Number: EDL-1932
$32.88
Old Jul 29, 2006 | 01:39 AM
Bob Onit's Avatar
Bob Onit
Did the 77's come with a hot air divorced choke from the factory?
Old Jul 29, 2006 | 02:46 AM
Kalway's Avatar
Kalway
Were the '75s the M4M? I always forget if the M4M came out in '75 or '76.
But ya, a 4MV (earlier model q-jet) is ideal because you can get the correct metering rods either from edelbrock or carburetion.com. The M4M (later model q-jets) only has the fatty M rods available new now and they make you run super lean at WOT. I believe JJ's smoking deals is all out of late model metering rods now, too. That's where I got like 5 pairs of rods for my M4M. I always stress people get the earlier model q-jets because of this.
I also say go for the electric choke conversion, it's easy to do and they're quite reliable. Of course during the summer it's sort of annoying, if you set it during the winter, because it'll close too far and make it all uber rich at startup. I had to tinker with mine to make it knock that off.
Old Jul 29, 2006 | 03:19 AM
Bob Onit's Avatar
Bob Onit
I beleive the change came in 75
When I had asked Lars about a carb for my 73 he told me "Any passenger car QJ from 1971 to 1974 would work fine,
I have nothing left from POST 74.. I gave them all away..
I have Doug Roe's book here so I suppose I can open it up and try to confirm this
Old Jul 29, 2006 | 03:44 AM
Kalway's Avatar
Kalway
Does the doug roe book point out any major differences between the M4M and the 4MV besides the float level and metering rod length?
Old Jul 29, 2006 | 04:22 AM
Bob Onit's Avatar
Bob Onit
Honestly Kal... I havnt had much time to read through it yet but from what I have read
I think its a MUST HAVE if you want to learn about Rochester carbs.
Old Jul 31, 2006 | 11:49 AM
Boofers's Avatar
Boofers
Actually yes they did have the hot air choke, what they didn't have was the vacuum break assembly.
To Questions about quadrajet applications
