cutting front springs???
Old Jul 28, 2006 | 12:40 PM
BLKDOUT's Avatar
BLKDOUT
Default cutting front springs???
I have gathered with the help of the "wonderful" search tool that it can be done, but do you cut the top or bottom. And any other info would be great. Springs are already out of car and ready.
Old Jul 28, 2006 | 01:23 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Bottom.
Old Jul 28, 2006 | 08:35 PM
uhvette's Avatar
uhvette
Default cutting springs
Hmmmm.....I cut the top, seats in the top A-arm great. I couldn't see cutting the bottom, the lower A-arm has less raised metal to keep the spring in place. In my case, 1.5 turns out of top of spring = 2.0 inch drop initially and then about another .5 inch when it settles in the next week or so.
Old Jul 28, 2006 | 10:01 PM
roger's 2937's Avatar
roger's 2937
Cut the top of the spring!!
Roger B.
Old Jul 28, 2006 | 11:57 PM
onaqwst's Avatar
onaqwst
grinder/band saw/cutoff wheel
no heat!!!!!!!
b
Old Jul 29, 2006 | 06:10 AM
ffas23's Avatar
ffas23
no heat!!!!!!!
b
Dam! No Heat? I put my cutting torch to the front springs used in my Street Rod and didn't have any problems. Must of been lucky that day.
Old Jul 29, 2006 | 06:32 AM
Twin_Turbo's Avatar
Twin_Turbo
Heat!!!! Cut them off torch the end cherry red, turn the spring around (of course don't grab the hot part ) and sit on it. That will flatten the cut off coil. Not only will the spring seat better (and not dig into the frame with the sharp end) but you will also immobilize the cut off coil, makinng it inactive. You will only be in trouble if you heat the active coils of the spring, sometimes you see bubbafied springs like that where they heat them to make them sag and lower the car...excellent for handling..not.
Old Jul 29, 2006 | 07:38 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You'll hear horrible squeeking noises if the spring is not seated correctly in the upper pocket.
The last coil must be flattened.
The biggest problem with cutting springs is that you don't know where your ride height is going to be. You want to be careful and not cut too much...... you may have to cut it twice ....
Once you've cut 2 coils off you can't just glue 1/2 coil back in place.... so don't cut too much the first time and let it settle before you decide it's not low enough (drive the car for at least 5 miles)
I would buy the 550lbs springs from VBP (wait.... I did)
Old Jul 29, 2006 | 07:42 AM
Twin_Turbo's Avatar
Twin_Turbo
If you cut off too much you can use a thick rubber spacer to raise the whole deal a bit..but indeed cutting twice is better than cutting too much in 1 go
Old Jul 29, 2006 | 06:17 PM
litevette's Avatar
litevette
I see you helping with mine in the future! (I hope you will!)
Old Jul 29, 2006 | 06:23 PM
uhvette's Avatar
uhvette
Default cut the top
portable band-saw
(It should only take a min to get threw)
on a side note: I bought an extra pair front springs just incase the cutting went bad. - I would recommend this.
Old Jul 29, 2006 | 07:05 PM
rihwoods's Avatar
rihwoods
On stock springs cutting 1/2 coil will generally drop front 1"....I cut my 78 FE7 springs with a torch...distance from ground to center top of wheel well lip is 26.5"...did not go lower as I was running 255-60-15's then...
Old Jul 30, 2006 | 12:47 AM
onaqwst's Avatar
onaqwst
i just heard about using heat would make the spring lose some of the compresion/spring to it....... maybe i was wrong..... i just used a grinder and hammered the ends flat
b
Old Jul 30, 2006 | 01:36 AM
rihwoods's Avatar
rihwoods
b
That is true if you overheat the entire spring...but a local cut near the end is quick and does not affect entire spring...when I did mine,it was in 1980 or so...all I had was a torch...
Rich
Old Jul 30, 2006 | 07:25 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
No problem.....
To cutting front springs???
