Alternator running hot
Old Jul 28, 2006 | 08:48 PM
1972's Avatar
1972
Cruising
Default Alternator running hot
I had a problem with the original alt. wanting to dress the engine a little at a time I went with a Tuff Stuff 100 amp chrome. Started Charging lite up to +60 but did drop, I figured I was just recharging the Battery. What I did notice and had not paid much attention before was that the alt. seemed to be very hot. Question is the running hot just the charge up or is it a fact that they just run Hot.
Thanks,
1972
Old Jul 28, 2006 | 08:55 PM
SIXFOOTER's Avatar
SIXFOOTER
OK, so what does "Started Charging lite up to +60 but did drop, " mean?
It should not run all that hot, and if the battery was getting charged at 60 amps you should have had a fire.
How did you connect the alternator? Is it a 1 wire or 3 wire?
Old Jul 28, 2006 | 09:17 PM
big_G's Avatar
big_G
Alternators get hot...that's why they have their own fan. Make sure your 'Vette doesn't have a parasitic draw, causing extra work for the alternator.
Old Jul 28, 2006 | 09:29 PM
SIXFOOTER's Avatar
SIXFOOTER
Electric tics?
Old Jul 28, 2006 | 09:31 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
if you arn't getting burned when you touch it, it's not hot.
If you do get burned you prolly have it hooked up wrong
Old Jul 29, 2006 | 02:41 AM
1972's Avatar
1972
Cruising
When engine first started up it peg my amp gauge then began to drop it is a single wire, factory clip on top, signle bat wire and a ground.
Old Jul 29, 2006 | 02:43 AM
1972's Avatar
1972
Cruising
what could be hooked up wrong? looks pretty straight forward.
1972's Avatar
1972
Cruising
To Alternator running hot
