All I want to do is to install the oil temp sender into my '81. I know it goes above the oil filter and there is a plug there. How in the he$$ do you get that thing out???
I tried it with the engine cold...nothing.
So I went for an hour drive to get it nice and warmed-up...and then tried...nope will not budge.
Do I have to get the torch out and heat this plug up? Or is there some trick to this??
Last July,when I removed my engine from my vehicle to change my torque convertor, I put my engine on a dolly and it fell over breaking off the oil sending unit. I took an screw extractor and twisted the remaining portion of the tube out. The sending unit that screws into the tube is of a different type of metal than the male end on the sending unit and over time, they fuse together. To make a long story short, Put your wrench on the nut on the sending unit body and the whole unit and tube should come out of the block. I dont remember where I got that new copper tube from. A hardware or an auto parts store may have that tube.
On my '81, it has never had the oil temp sender installed...it only has a plug in the hole above the oil filter. It's this plug that I am trying to get out.
The plug is the same type that is screwed into the heads for water temp sensors or radiator fan switches. I know to get those out requires heating with a torch. I had thought that a hot engine would have been enough to let me ease that plug out...but nope.
