69 C3 battery issues
Old Jul 30, 2006 | 06:39 PM
rabiddawg's Avatar
rabiddawg
Default 69 C3 battery issues
found car battery dead 2 days ago .recharged and getting 14.3 vdc at battery terminals with engine running.
battery is new btw.
next morning dead battery again!
recharged and did a bit of troubleshooting.
when i disconnect the positive lead i hear a click in the dash console area?
what can the culprit be?
my next step is to pull fuses 1 at a time to narrow it down.
Old Jul 30, 2006 | 07:15 PM
big_G's Avatar
big_G
Bet ya a steak dinner the wiper motor is jammed. Feel the motor..is it hot? The clicking you hear is the wiper relay. If you bumped the wiper switch with the ignition on, but the wiper door and wipers did not complete a full cycle, the wiper motor won't shut down. Even if you turn the key off. A flaw in the design. You need to open the wiper door and get the wipers to cycle and park.
Old Jul 30, 2006 | 07:22 PM
rabiddawg's Avatar
rabiddawg
ill try that
hmm i also noticed that i have to nudge the wipers down a bit so the wiper door sits flush .
i might have to reposition the wiper arms aswell.
Old Jul 31, 2006 | 06:17 PM
rabiddawg's Avatar
rabiddawg
someone also said to check the clock?
something about the rewind function sticks sometimes and runs the battery down?
Old Aug 1, 2006 | 01:34 PM
68sbShark's Avatar
68sbShark
My 68 had the exact same issue that you describe. Reach up behind the tach and feel for the wiper door solenoid. There should be an electrical connection it as well as 2 vac connections. I bet you it is warm to the touch (with the battery connected of course). Have a helper disconnect the batt while you have your hand on the solenoid. You should hear/feel it click. If this is the case, you need to check the park swtich for the wipers. Does your wiper door work OK, or does it stay up?
~Rich
Old Aug 2, 2006 | 06:33 AM
rabiddawg's Avatar
rabiddawg
wiper door stays partially up due to right wiper arm touching the door.
Old Aug 2, 2006 | 12:03 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Wiper relay under the console...up in front of the ashtray.
If your door isn't down, the wipers may not be parked "all the way", keeping the circuit open. Chuck
To 69 C3 battery issues
