Dash lights on a 73
Old Jul 31, 2006 | 11:39 AM
Skruball73's Avatar
Skruball73
From: Inside every color vette there is a blue one trying to come out!
Default Dash lights on a 73
I have 2 dash lights that have gone out. They should illuminate the right side of the speedo & the left side of the tach. what needs to be done to replace them?
Old Jul 31, 2006 | 11:51 AM
73 red vette's Avatar
73 red vette
I reached mine from the underside of the dash. you might have to drop the steering column a bit. It is a pita but it's better than pulling the dash out.
lotsa luck
Old Jul 31, 2006 | 11:53 AM
PETKAH's Avatar
PETKAH
Default Dash Lites
Refer to a manual to see exactly where they are connected
on the back of the speedo and tach (these lights "plug in"
to the back of each gauge.) If you are lucky and they are on
the bottom of the gauges you might be able to replace easily-
that means lying on your back with a light and changing.
If not lucky you are in for a major project - take the drivers
dash off - while you are there replace all bulbs.
Old Jul 31, 2006 | 02:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yup. PITA. Go slowly. It's easy to have the lamp sockets pop off only to leave the little metal contacts stuck in the cluster. Worse yet, fall into the speedo/tach.
To Dash lights on a 73
