i recently installed dynomax blackjack ceramic coated headers and my plug wires are touching the headers and will eventually burn through. will buying wires with the angled ends correct this problem or is it a waste of money????
Buy a quality set of plug wires with 90 degree boots, ACCEL,TAYLOR or MOROSO. Also, you may want to consider a set of "shorty" spark plugs. Even with Moroso wires, I had to use "shorty" ACCEL spark plugs to obtain enough clearance between the header and the wire.
You're going to need some wire looms that route the wires over the top of the headers and use the 90 degree boots as suggested.
can you just get those looms anywhere or where did you guys get them? thanks for the responses too they really helped i went with msd super conductors but all i lack is those wire looms
Go to http://www.summitracing.com/ and type in the search box "wire looms" and you'll get hundreds of choices. Buy a set of cut to length wires also. You need to cut them the right length because most of the regular replacement wire sets will be to long. Need to keep it neat and tucked in close to the block so they don't get burned by the headers.
