Water Wetter
Old Jul 31, 2006 | 04:34 PM
geoc's Avatar
geoc
Default Water Wetter
On my 78 on the road my temp. gets up to about 240 deg.. I have a low temp. thermostat. Would adding a bottle of Red Line Water Wetter lower the temp.
Old Jul 31, 2006 | 04:42 PM
PhotoVette1's Avatar
PhotoVette1
Didn't help mine a bit--except for turning the nice green coolant into something that looked like it was mixed with old blood.
Old Jul 31, 2006 | 05:03 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
snake oil, don't waste your time.
You have other issues.
dshanks's Avatar
dshanks
Yuck!
Is it possible that the water wetter had some type of detergent that cleaned some rusty grime from your water jackets, and began to circulate it through the system?
Old Jul 31, 2006 | 05:11 PM
Nemesis_152's Avatar
Nemesis_152
waste of time and money. it gave not one degree of difference in my old s-10. i would NOT use the product again. there are likely larger cooling system issues that you're facing if you're running 240F water temps. the thermostat should make no difference in actual operating temperature.
for instace:
make sure that your fan shroud is correct and correctly sealed
ensure that the lower radiator hose is not collapsing
ensure that your water pump is in good condition
ensure that your thermostat is opening (and evan switch to a fail-open type)
sesure that your air dam is installed correctly
if e-fan, make sure that the fan is properly mounted and sealed to the radiator as appropriate
make sure you have a good water/coolant mixture
if needed, make sure you have steam holes in the heads
make sure you've bled the cooling system for air pockets (never had the problem personally, so i dont know much about it)
Old Jul 31, 2006 | 05:35 PM
PhotoVette1
Originally Posted by dshanks
Yuck!
Maybe, but my system is pretty clean--motor 3yo, aluminum radiator 1yo.
Old Jul 31, 2006 | 05:37 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Water wetter works, but only if you run it with pure water... It makes very little difference if used with antifreeze..
Old Jul 31, 2006 | 05:39 PM
GrandSportC3
Water Wetter is NOT snake oil! It does work and I did before and after tests to see it's effects! Water Wetter + pure water ran 20+ degrees cooler than pure water alone in identical conditions! Water Wetter does work!!
It will hardly do anything if antifreeze is used..
Old Jul 31, 2006 | 05:45 PM
Kalway's Avatar
Kalway
If you've still got your original radiator, its probably clogged or in need of replacement. My '81 was having that problem and I replaced the old 3 row copper with a 2 row aluminum from Northern factory and now it doesn't even get over 200 degrees during autocross.
Old Jul 31, 2006 | 06:13 PM
Nemesis_152
does the product have boiling point elevation properties like anti-freeze?
Old Jul 31, 2006 | 06:21 PM
dshanks's Avatar
dshanks
I believe that it works by reducing the surface tension of the water to allow it to more thoroughly contact the cooling surfaces of the radiator.
Old Jul 31, 2006 | 06:22 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
Default From Redline's web site:
WaterWetter®
WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations.
Old Jul 31, 2006 | 06:25 PM
NeverFinished's Avatar
NeverFinished
I tried it too. Apparently it seemed like a waste of money because I used it with antifreeze and water. Additionally, it made the coolant mixture smell awful.
I'm not sure I would run pure water. The last time I did the rust built up quickly and made a mess of the radiator. I can't imagine the boiling point being elevated significantly by using the water wetter.
Old Jul 31, 2006 | 06:53 PM
ThunderMaker's Avatar
ThunderMaker
Don't waiste your money on water wetter...pull out your t-stat first and run without it and see if that helps. It will only cost your the price of a gasket to see if this helps.
Old Jul 31, 2006 | 07:24 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You need to fix whatever is causing your problem, Water Wetter is not intended to fix overheating problems. It does reduce operating temperatures somewhat. I have used it on 2 separate motors with antifreeze and both times 2 bottles of the stuff have reduced the temps by about 10degs F. Only one bottle tends to do very little.
Old Jul 31, 2006 | 07:49 PM
Kalway's Avatar
Kalway
Whenever I hear water wetter I always think of computer water cooling systems. It's the water additive of choice for water cooling systems in computers. All it's basically supposed to do is prevent galvanic corrosion and prevent air from building up. However, most computer water cooling systems are nothing but plastics (tygon, clearflex, vinyl, etc.) and copper. If it's just copper/bronze in the system then galvanic corrosion isn't something that really has to be worried about, but algae is. Which is something water wetter also prevents.
However, for the price, those of us that watercool our computers, sometimes just use a 10 - 20% mix of anti-freeze and forget about it because you have to constantly add/change the water in the system anyways. I just use plain tap water now since my whole system is just copper and vinyl.
Basically, water wetter isn't really worth it, in my opinion. Probably need a new radiator or water pump.
Old Jul 31, 2006 | 07:54 PM
larry hinterman's Avatar
larry hinterman
I used water wetter with water only in the radiator in my hi-compression 64. That was the only combination that solved the temp problem with that car.
To Water Wetter
Old Jul 31, 2006 | 09:17 PM
GrandSportC3
I ran 2 bottles of water wetter with purified water for 3 years in the 383 that I used to have in the car and there was no rust. Water Wetter is a great rust inhibitor!
Old Jul 31, 2006 | 09:18 PM
GrandSportC3
Indeed, one bottle does very little!! You definetely have to use 2!!
Old Jul 31, 2006 | 10:43 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Putting a allum rad in a c5 Z06 today(shop i work @) and manual sez to put 2 bottles of water wetter w/ a 25% coolant- 75% water.
I hear the stuff work great with allum heads - radiater.
