timing - distributor advance curve
Old Aug 5, 2006 | 01:22 PM
  #41
MsVetteMan's Avatar
MsVetteMan
Originally Posted by driver68
I will take Barry's advice and find another dist and just store my original.
Gary
I believe I suggested that back in post #24
Old Aug 5, 2006 | 01:30 PM
  #42
driver68's Avatar
driver68
msvetteman
no that is not what you said. you said I should "trash" my original. That is quite different from buying a new one and "storing" the original!
Old Aug 5, 2006 | 01:38 PM
  #43
driver68's Avatar
driver68
Well, why not just trash the disrib. and buy a new one, and be done with it? The drama is killing me.
Not quite the same as Barry's advise!
Old Aug 5, 2006 | 02:37 PM
  #44
...Roger...'s Avatar
...Roger...
Driver I was checking some more distributors and it looks like that bushing will give you about 8* more-that should leave you with 12* initial.You should like the results. Let us know for future reference.
Old Aug 5, 2006 | 03:08 PM
  #45
BarryK's Avatar
BarryK
if that's true than you should be perfect (and easy!!!)........ 12º initial / 36º total plus 15º vacuum advance. Can't ask for much better than that!
be sure your vacuum line is running off a full manifold vacuum source also
Old Aug 5, 2006 | 03:09 PM
  #46
Bob Onit's Avatar
Bob Onit
INITIAL+CENTRIFUGAL=TOTAL+VACUMN=MAX
Now that is a great way of defining the timing
Why diddnt I think of that.....oh, thats right..... cuz im stoopit
I have two stock 1973 distributors....Is there anything I can measure to help resolve this?
I will say, I bought a Moroso kit before checking my total timing because the car was about 95% stock and to my surprise Im had about (trying to rember) 36* @ 2,700 RPM and 53* (lets try a new word ) Max @ 2,700 or so
Anyhow, as far as I can tell there must have been a curve kit installed but its hard for me to beleive because I have talked to both previous owners and there was no mention of any work done on the Dist.... Plus neither one knew which end of a screwdriver to hold and last, the initial timing was set at 8* when I bought the car.
Old Aug 5, 2006 | 03:14 PM
  #47
Bob Onit's Avatar
Bob Onit
Hey Barry!
I have the same readings but I'm using a ported vacuum for the advance.... Should I try the full vacuum even if it's fine with the ported?
Old Aug 5, 2006 | 03:28 PM
  #48
driver68's Avatar
driver68
ok guys, here are the results of my new curve with NO bushing at all:
I have the silver springs in - not sure if they are the medium ones or not, but they are not the lightest ones, and original weights.
vacuum disconnected.
700 rpm (idle) 12*
1000 rpm 19*
1200 rpm 22*
1500 rpm 25*
1800 rpm 30*
2000 rpm 31*
2200 rpm 33*
2500 rpm 37*
3000 rpm 38* (all in)
This looks pretty well perfect to me. Barry & others, what do you think?
Old Aug 5, 2006 | 03:48 PM
  #49
Bob Onit's Avatar
Bob Onit
700 rpm (idle) 12*
1000 rpm 19*
1200 rpm 22*
1500 rpm 25*
1800 rpm 30*
2000 rpm 31*
2200 rpm 33*
2500 rpm 37*
What does it read with the vacuum advande hooked up?
Old Aug 5, 2006 | 03:51 PM
  #50
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Default maybe you resolved my issue, also
Don't mean to hijack this thread, but seems like you've solved Driver68's timing question, maybe mine's kinda the same. Using your new terminology, I've got 12 initial plus 18 mech. = 30 total plus 11 vac. = 41 max (did I do that right?) My #'s don't add up right though, when hooked to manifold vac. at idle, I've only got 21 deg which is only 9 vac. Am I making this too complicated, it's giving me a headache.
Anyway, could my distributor also be set up for only 18 deg. of cent. advance? '79 L82 & I've got the springs that give me all in by 2600 rpm.
If I crank in more initial, won't that be too much at idle? I'm at 21 deg. now.
Again, not trying to hijack your thread, Driver68, but sounds like I've got the same thing.
Thanks, ya'll. This forum is a tremendous asset for us people that know which end of a screwdriver to hold (tip of the hat to Bob Onit ), we're just not sure what to do with it!
Old Aug 5, 2006 | 03:56 PM
  #51
BarryK's Avatar
BarryK
Originally Posted by Bob Onit
Hey Barry!
yes I would.
full manifold vacuum advance typically gives better idle characteristics, better throttle response, a cooler running motor, & better fuel economy.
There seem to be some cases where it runs better on the ported, but usually it will be better on Full manifold vacuum. Try switching it and see.
Old Aug 5, 2006 | 04:00 PM
  #52
BarryK's Avatar
BarryK
700 rpm (idle) 12*
1000 rpm 19*
1200 rpm 22*
1500 rpm 25*
1800 rpm 30*
2000 rpm 31*
2200 rpm 33*
2500 rpm 37*
works for me as long as he doesn't get detonation at the 38º. some motors can go that high, others will detonate. He can only try it and see what happens. Nat tomention that his particular distributor may end up giving a slightly different amount of timing by a degree or two based on it's condition, etc.
driver, if you try it without the bushing, and are getting the same numbers, and IF it detonayes, just back it down 2º at a time until the detonation stops.
Old Aug 5, 2006 | 04:01 PM
  #53
BarryK's Avatar
BarryK
it would be 15º more on all as I think he said his vac can is adding 15º of advance.
Old Aug 5, 2006 | 04:16 PM
  #54
BarryK's Avatar
BarryK
if you tell us what distributot you have perhaps Dwncch can look up in his magic book and tell us what mechanical advance your distributor is suppose to have.........
one POSSIBLE reason that the numbers don't seem to add up is that the mechanical may be coming in too soon so your 12º initial at idle might possibly be including some of the mechanical
Old Aug 5, 2006 | 04:18 PM
  #55
Bob Onit's Avatar
Bob Onit
yes I would.
Ok..... Ill give it a go
Thanks again!
Old Aug 5, 2006 | 05:51 PM
  #56
...Roger...
Capt.-the book for a 79 L-82 shows you should have 16*cent.@2000 and 10* vac.with 12* initial soooo with vac. disconnected and RPMs at 2000 you should have 28* total advance -if you hook vacumn back up and RPMs at 2000 with light throttle you should have 38*(max)--If you try to get 36* total your initial will be 8* too much.If you hope to get to 36* total you will have to increase your cent.advance range.
Old Aug 5, 2006 | 06:03 PM
  #57
...Roger...
700 rpm (idle) 12*
1000 rpm 19*
1200 rpm 22*
1500 rpm 25*
1800 rpm 30*
2000 rpm 31*
2200 rpm 33*
2500 rpm 37*
Driver -sounds like removing the bushing got you 10* your vac.advance is 15* @ 15.5" of vacumn you might get lucky with the 38*if you run good fuel---but keep listening for the pinging-How does it run? Good I bet. Let us know if it woke it up!!!
To timing - distributor advance curve
Old Aug 5, 2006 | 06:11 PM
  #58
MsVetteMan's Avatar
MsVetteMan
I guess you don't realize that this---> means one is joking.
Don't make a chit to me who helped ya, glad you got some help.
Old Aug 5, 2006 | 06:17 PM
  #59
...Roger...
Barry- sounds like Driver got 10* by removing bushing-I measured the bushing and it .035 thick so by removing it gave .070 more movement forward and back.So for every .007 total- you change by 1*
Old Aug 5, 2006 | 06:27 PM
  #60
Capt. Shark
Thanks, dwncchs. Sounds like the distributor is on specs. That's pretty much the #'s I have. Can I do anything to increase the mech. advance & will I benefit from it? Driver68 removed a bushing. Can I do the same on my HEI dist? When I got it, the mech. advance was jammed & not working, so it's already much better. This as far as I can go with it?
Thanks a lot.
