Lights on 76 and switches
Old Sep 5, 2001 | 04:01 PM
Dwayne 76's Avatar
Dwayne 76
Default Lights on 76 and switches
Hello again. My Vette has lights on the front grill, they look stock but are they. If so, how do I turn them on, can't seem to find a switch to do it. Also speaking of switches, there is one on the Drivers side tranny hump, just ahead of the dash, is that stock?? It dosn't seem to do anything, maybe for the rear defog?? I donno. I checked the manual, but don't RECALL seeing anything about those lights and switch, then again I don't have the manual on me...so I can't check it now anyway.
Thanks Agian
Dwayne
Old Sep 5, 2001 | 04:05 PM
R. Bruno's Avatar
R. Bruno
Default Re: Lights on 76 and switches (DwayneHillier)
Lights are parking lights should come on when you pull the light switch halfway out and stay on with the head lights. The switch is stock, my car has it and I believe operates the rear window defogger but have not used it..
Old Sep 5, 2001 | 04:08 PM
Dwayne 76's Avatar
Dwayne 76
Default Re: Lights on 76 and switches (R. Bruno)
ahhhh, thanks, that makes sense. So considering I've never seen those lights on, I guess its just a straight wire trace to the break or problem in the wire.
Thanks again
Bruno
[Modified by DwayneHillier, 8:09 PM 9/5/2001]
Old Sep 5, 2001 | 05:09 PM
R. Bruno's Avatar
R. Bruno
The wiring diagram shows those lights clearly. Check the ground first. May also be the switch.
To Lights on 76 and switches
