KUDOS! Paint Strippers
Old Aug 1, 2006 | 02:45 AM
sam74c3's Avatar
sam74c3
Default KUDOS! Paint Strippers
Someone posted a thread about doing this with razor blades. I had'nt heard of this before and had to try it on my 74 with it's many layers of peeling paint.(Rebuild Project) Anyway, it worked great! And no fumes or slimy mess either. So THANKS! But I've got a new question for ya...Has anyone ever had a bad experience with the older OEM primers underneath the newer primers. Like..bad adhesion or anything?
Old Aug 1, 2006 | 09:28 AM
EDDIEJ82's Avatar
EDDIEJ82
Wipe it down good with DX440 and spray a coat of epoxy sealer on it. This is the way I did mine and it's holding fine.
Old Aug 1, 2006 | 10:22 AM
BarryK's Avatar
BarryK
it may or may not make a difference and I'm no painting expert by ANY means but i've got the second Vette in two years in the paint shop now so have formed some opinions anyway.........
I much prefer to strip a car all the way down to the bare fiberglass. Take off all old paint and primers and start the new paint job with a good clean, fresh fiberglass base. by starting that way, and putting on all new primer coates, sealers, and paint you know it's done rigt and everything is new and no problems. It also allows to see the condistion of the bare fiberglass to know if any repairs or problem may exist that should be repaired first.
also, in know that that spraying different types of paint over old types can cause issues from incompatibilities so it it's original primer it would have had lacquer paint over it. if you spray basecoat/clearcoat paint over that old primer there is always a chance some residue from the lacquer is still sitting in that old primer that could vent out and cause issues for you down the road against the BC/CC paint.
on the other hand, some people do just strip down to the base primer, sand it smooth and leave it and don't seem to have problems so maybe it's not always needed to go to the bare 'glass but I prefer to do it that way
Old Aug 1, 2006 | 12:27 PM
swensonm's Avatar
swensonm
Default Blades
So to strip with a razor blade you just start scraping?Does the fiber glass get nicked up?
Need to work on my paint!
Mike
Old Aug 1, 2006 | 12:37 PM
desi's Avatar
desi
How long (hours) did it take to strip the entire car with blade?
Old Aug 1, 2006 | 12:54 PM
big_G's Avatar
big_G
It all depends on how well the paint bonded and how many re-paints. I've stripped 'Vettes in as little as 8 hours. Some cannot be razored at all. Try a small area and see how it goes.
Old Aug 1, 2006 | 01:11 PM
73C3's Avatar
73C3
I stripped my car with a razor and found it to be really easy.
I found that the razor will work good with multiple coats of old paint. If you get the paint to thin like scraping just the top layers off first, it will be difficult to get the remaining layers off with the razor. Go all the way down the first time.
If the paint is to thick, the razor will work but the edges curl under which will give you a nick in the fiberglass that you will have to repair.
Be carefull and take you're time. Start at an existing chip and gentally work it so you will begin to make a "path" for the razor. Work it in several directions and make sure you have plenty of sharp blades on hand.
Use quality razors, cheap ones will break almost immediatly or will curl under damaging the fibeglass.
Good Luck!
Old Aug 1, 2006 | 02:43 PM
rcastor426's Avatar
rcastor426
so what is a good quality razor? I am not sure of any name brands size, type etc
Old Aug 1, 2006 | 03:07 PM
73C3's Avatar
73C3
I am not sure of the brand name but the razors that worked best for me came from Home Depot. Worse came from Wal-Mart and ACE Hardware. I used the single edge type of blade on a scraper handle.
Old Aug 1, 2006 | 03:26 PM
TopGunn's Avatar
TopGunn
So how do you handle the curved surfaces and inside corners? Seems like allot of little dings in the fiberglass. Or does it pop off that easily?
It sounds like a nice project for the winter for me especially since I can't wash off chemical strippers when it's 20 deg outside.
Old Aug 1, 2006 | 05:01 PM
73C3's Avatar
73C3
Get the sandpaper out for the inside corners.
It pops off quite easy once you get a start at it. The original paint is quite tough and requires more patience.
Old Aug 1, 2006 | 11:40 PM
bondoboy's Avatar
bondoboy
Round off the corners of the blade on a grinder and you won't gouge the body as easy.
Old Aug 1, 2006 | 11:46 PM
Glassbowtie77's Avatar
Glassbowtie77
Stanley 100 pack is what I used to do mine. Got them at Lowes or Home Depot.
Old Aug 2, 2006 | 01:56 AM
GDaina's Avatar
GDaina
There is no reason to strip the factory primer
Old Aug 2, 2006 | 03:17 AM
BarryK's Avatar
BarryK
depends....... if you need to do any bodywork and fiberglass work you would want to get down to the bare 'glass.
on my '65 after stripping we found a lot of bodywork and fiberglass work that had to be done and it wasn't seen until ALL layers were taken off including the last layer of primer.
The '78 which is just finishing up in the paint shop now needed obsolutely zero bodywork but we still took it down to the bare 'glass and that car still had the original untouched lacquer on it which was in bad condition including some cracking in the paint that went past the paint and thru the primer coat to the fiberglass. Again, we stripped it all the way down to the bare glass to start with a all new, fresh, clean surface.
Again. some people's methods and opinions on this vary, but personally my feeling is on any corvette that I'll ever get repainted I'll take down to the fiberglass first.
Old Aug 4, 2006 | 02:42 AM
sam74c3's Avatar
sam74c3
Thanks for the input. Everything posted seemed true after I had stripped about 1/4 of the car. I had lots of layers, so it did come off easier than the spots which had been sanded and were thin. I also had problems with cheap razors breaking.
Old Aug 4, 2006 | 09:09 AM
GDaina's Avatar
GDaina
Of course, that goes without saying, but otherwise, no need to. If by chance there was body work done, it would stand out like a sore thumb.
To KUDOS! Paint Strippers
