Intake manifold shoot out question?
I'm lucky enough to live and work 10-15 minutes from the Sparks Nevada Summit Racing distribution center. So they have quite the speed shop store here. So on various projects i go down and buy 3 different vendors parts and take them home and look them over before installing what I think is the best.
When i pick out manifolds I include Edelbrock. They consistantly suck
Very poor casting quality and they require man hours of port matching die grinder work. So i look and take them back!Just lay a FelPro gasket on the Edel intake and it doesn't even come close to matching. On the other hand Weiand, world products, Dart, Holley intakes that I have bought required very little time to match up.
Years ago I had a Edel VJ. Lot's of man hours and epoxing in "turtles" to get a balanced flow without excessive fuel drop out. It was just a poorly designed product.
You should not have to dork with a manifold. The VJ is at least a 15 year old design. The sad thing is they still use the same design.
I did RWHP on my old 355 ci Vette motor. Back to back testing and the Edelbrock "Performer" made significantly less HP than the stock aluminum 79 L-82 manifold.
Car rags sell out to the highest bidder
I would like to see shoot outs vs the old OEM stuff, with torque numbers and OEM stuff modified/ported to flow. I would be willing to bet some of us would stop spending our cash on the after the market. I am convinced much of the stuff is not up to what it claims. And some of our "favorite" rags don't help.
carbster
carbster
I just don't understand why the hot rod rags are so afraid of stepping on their advertisers toes with an honest review. Look at "Road and Track" or "Car and Driver", they hold nothing back reviewing cars and they still manage to hang on to advertisers. "Grass Roots Motorsports" is another good example of a magazine that does their best to accurately review and compare products.
The aftermarket suppliers would really clean up their act if they had the hot rod mags doing objective reivews. And we, as the consumers, would greatly benefit.
Heck, I've seen cam and carb shoot outs with different magazines.
It just seems pretty strange to me.
I say you pull them out of a box and then you can optimize the carb and timing accordingly for each unit.
I always see them with Edelbrock units.
Not true. I've seen a couple of time in Hot Rod where they started with the Edelbrock and switched to a Demon for the last run which always made more power......
You can't lump all carbs of the same CFM rating into a class and say that this one comes out on top. Demons are rated low on CFM just so they can say that their 750 can beat all the others dyno numbers. All you have to do is buy an aftermarket probuilt holley and see which carb really runs the best in the real world and puts out the best numbers.
I ran my 750 Edelbrock carb for 10 years on my hot rodded Vette. But I understood how it worked and put alot of time in on a rear wheel dyno with exhaust sniffers. Everything on it, down to the 1/2 wood thermal spacer above the single plane intake was optimized for the best fuel curve possible. I had freeway mileage of over 21 mpg on long trips with th350 and 3.55 rear gears driving 85 mph for hours on end.
520 540 lift,felt like it needed more air ,bought the Weind team g intake ran a little better,so then swap out to a 427sb ,same team g intake heard about this manifold shootout in one of the mags and one of the stroker books had the same article where the Professinal products single plane manifold whipped all the others,so I bought one and swapped out ,and the motor felt so much better,could have been because of the higher rise,but it sure freed up some more ponys,
around 30 hp ,but youll need a bigger hood
