Headlight Aiming Procedure
Old Aug 3, 2006 | 09:32 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Headlight Aiming Procedure
I drove my vette for the first time at night Tuesday and I see how poorly my headlights are adjusted. Anyone have a setup procedure that they use or is it in the assembly manual?
Old Aug 3, 2006 | 10:00 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Dont know, but position the vette @ the end of your driveway and aim the headlights @ your garage door (20 or so ft away) and see how the lights aim . to low to high? and start adj from there. I dont know about other c3 owners out there but i here alot of this complaint. I avoid driving my 82 (if i can) @ night cause of that reason.
Would upgrading to a 100 amp alt vs 70 amp alternator make a diff ?
Old Aug 3, 2006 | 10:13 PM
...Roger...'s Avatar
...Roger...
Do a search for "headlight aiming" there are a couple
Old Aug 4, 2006 | 09:23 AM
Vette Gator's Avatar
Vette Gator
There's a method in the Haynes manual that works pretty well.
Old Aug 4, 2006 | 09:35 AM
Nemesis_152's Avatar
Nemesis_152
no, but a headlight relay setup would.
www.madelectrical.com
Old Aug 4, 2006 | 10:03 AM
mandm1200's Avatar
mandm1200
I use the garage wall and make adjustments. Take the car for a spin and readjust. I have seem headlight aiming devices at local garages. They always had an inch of dust on them from not being used.
Old Aug 4, 2006 | 10:35 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
havent seen one of those in years
After putting halogen bulbs in all 4 holes, waited till it got dark, went to empty parking lot, adjusted till they were right
KISS
T
Old Aug 4, 2006 | 10:44 AM
theandies's Avatar
theandies
Eddie - I think it is in the AIM.
Old Aug 4, 2006 | 10:52 AM
sweethence's Avatar
sweethence
It is, and i tried it, but tweeked it witht he method above
Old Aug 4, 2006 | 02:34 PM
JPhil's Avatar
JPhil
I typically use a long dark county road and a couple pieces of cardboard to cover the other lights while I'm aiming one at a time. Then I drive back to town and see how many people flash their brights at me. If it's a lot, I tweek 'em down a bit. Pretty unscientific, but it works for me.
John
Old Aug 4, 2006 | 07:10 PM
Eddie 70's Avatar
Eddie 70
Well, thanks for all the help. Now I have something else to go out and tweak just a little bit.
Old Aug 4, 2006 | 09:08 PM
jdmick's Avatar
jdmick
A lonely road works for me. Make sure you put in halogens if you haven't already.
Old Aug 4, 2006 | 10:23 PM
Sayfoo's Avatar
Sayfoo
KISS
T
You can measure this and measure that, but it really is easy to do as above.
Old Aug 4, 2006 | 11:15 PM
Cookwithvette's Avatar
Cookwithvette
My headlights were quite dim when I first got the car but after cleaning the terminals they perked right up.
If you're trying to make sure you are getting the most from your lights I would suggest taking the terminals out one by one and cleaning them with some fine sandpaper. I also use some Ox-Guard dielectric grease when reinstalling.
Old Aug 5, 2006 | 12:07 AM
JoeRags's Avatar
JoeRags
ehh... I'm in the same boat. Past few nights have been the only real night cruises I've taken with the car. They are way out of adjustment. I may do a relay soon as well to try and help it out.
I would love some xenon's in there...
To Headlight Aiming Procedure
