700r4 conversion
Old Aug 4, 2006 | 06:54 AM
straub18045's Avatar
straub18045
Default 700r4 conversion
I just wanted to say that i recently had a 700r4 conversion and it was the best thing i ever did to my '79 vette. It has a continental converter variable stall w/ non lockup(no computer mess). it was build to the highest stantards unbreakable. This guy says you cannot build one stronger. Can't believe how it woke up my old engine, and the cruising on the highway with low rpm's-priceless.
Old Aug 4, 2006 | 07:01 AM
fl_rider's Avatar
fl_rider
Default Congratulations !!
That only adds fuel to the fire for me and my 78.
Old Aug 4, 2006 | 08:53 AM
mrvette's Avatar
mrvette
Can you ask your builder to be very specific in describing what he did to solve the 3/4 clutch pack overheating problems?? what clutches and steels he used, and how he changed the oiling passages, and what he did about the weak drum issue??
also what shift kit he used?? I would like to hear his exact specific response.....
Old Aug 4, 2006 | 10:34 AM
straub18045
ok, i was home for 2 weeks from kuwait-im currently serving in operation iraqi freedom in the army. within 2 weeks he completed the project. i dont have the bill in front of me so i cant be to specific. but i can tell u what i remember. converter- continental this one is the best but its expesive 800-900$ its a variable stall, it works with my stock motor and will work with a performance motor. the sunshell is a "beast" brand name, the best . used a transco shift kit, with this kit he had to machine the case a bit to fix the lubrication of the clutches to prevent over heating, using amzoil sythetic fliud 20-40 degree drop in temp. 93 vette servo, and on and on but that is all i retained i can see if i can get it scanned to me. he also said stay away from b&m, tci and so on because they make junk there products actually hurt the tranny. basically this guy does these conversions for a living. he spent decades find the right recipe of parts and this combo he bragged about to me. well whe i drove is-holy crap! i couldnt believe it, plus no lockup!
Old Aug 4, 2006 | 11:13 AM
straub18045
-bow tie overdrive cross member, beautiful fit, like a glove, can run any size exhaust
Old Aug 4, 2006 | 01:15 PM
TexSon's Avatar
TexSon
Suprised you have a non-lock converter. It will run a bit cooler (the transmission) and lower RPM (~200 rpm) with it locked. There are several lock-up kits out there (B&M, Painless, etc.) for about $160 and less. I put the B&M on my Wrangler when I installed the 350 and 700R4 in it because it allowed me to set the lockup speed. It also has a button to allow you to turn off the converter, which is nice for passing. And it also dropped the transmission temp. Worth the money IMHO.
Old Aug 4, 2006 | 10:32 PM
halfshaft's Avatar
halfshaft
Don't forget the lower 1st gear ratio. The 700r4 swap dropped my ET's by 2 tenths in the 1/8.
Old Aug 5, 2006 | 01:16 AM
straub18045
i am aware of the lockup kits. they are not durable over time. this tranny cools better than a lock up because of the converter, 10 inch continental. no problems with slip speed or anything. ive done over a year of research on this project, also i work at as a gm tech, im not a performance expert, but i no trannies. this was the best for my vehicle, maybe others have succes with trannys but i no this is the best. guy down the road has the same tranny, 600 horse and he cant break it, but everything has its breaking piont, just saying i know its good.
Old Aug 5, 2006 | 02:41 AM
mrvette's Avatar
mrvette
S180, thanks for your service, stay safe, obviously.....
I have fought over my 700 twice now, and it's got a superior/fairbanks shift kit, I wonder if I can change over to Trans Go....I had several of their kits over the years in 350-400 trannies, and they flew pretty good, one of them for over 300k miles still banging a good gear....
Old Aug 5, 2006 | 08:24 AM
windsoreight's Avatar
windsoreight
mrvette most of the problems you describe are from the early 700. When they went to 4L60 they did many upgrades. They changed the 3-4 clutch pack. They also beefed up the drums. Really the main problem they had was breaking the reaction shell. They soon had a beefier replacment. I am partial to the 700/4l60 and found them to be very strong. My lifted daily driven 93 Suburban still had it factory 4L60E with over 250,000 miles when I sold it. It had only been serviced and had one shift solenoid replaced. One I built lives in a 10 second street drived tubbed 69 camaro with a big block. So you can build them to take lots of abuse.
Old Aug 5, 2006 | 09:48 AM
jdmick's Avatar
jdmick
That's interesting. I like the lockup feature but I'll admit it added to the install time and cost and the vacuum disable switch can be kind of a PITA. Did you install a temp guage?
Old Aug 5, 2006 | 10:02 AM
straub18045
na no temp gauge this particle set up has been tested and tested no were near overheating
Old Aug 5, 2006 | 10:03 AM
straub18045
keep in mind with the clutches used, there was machined to the valve body and case as to increase cooling
Old Aug 5, 2006 | 10:22 AM
mrvette's Avatar
mrvette
OK, I have heard of this increased cooling, what was drilled, what size, and what tool??
Reason I asked is shipping one of these things is stupidly high priced, and very awkward to handle, and they are in reality fairly generic units' mine is a late '87 unit with a aux valve body , and SUPPOSED to have most of the updates installed when it was built in '97, the second 3/4 clutch pack is still in there, I thought it wasfailing yet again a year ago, guess I was rong....I even have a replacement part set for it sitting under this table now....
but since I don't drag race, I find that 1st gear about useless....
and for 50 lbs savings with superior design and reliability, I think I may well go for the 200 4r and have over with it...
Old Aug 5, 2006 | 10:51 AM
silverslashstreak's Avatar
silverslashstreak
Anyway you cut it, overdrive is about the best mod you can do to a c2-3, lower first gear, great cruising gear. The next best is a jeep steering box.
SSS
Old Aug 6, 2006 | 01:23 PM
straub18045
it will take me awhile to retain this info because of my excessability to the itemized bill, i got my vette back 12 hours befor my plane left could chit chat to much with the guy. i wanted to drive it for as long as i could. keep in mind 2004r is longer, not sure what crossmembers and such thay have for it
To 700r4 conversion
