Greasing wheel bearings?
Old Aug 5, 2006 | 06:35 AM
kb2fzq's Avatar
kb2fzq
Default Greasing wheel bearings?
I have been contemplating greasing all the wheel bearings and when looking in the Haynes manual, I can't seem to find a description...does anyone know of a web site that describes this procedure?? I've done standard cars in the past....something tells me the vette will be.....ummm, "unique"
Thanks....
Old Aug 5, 2006 | 07:28 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The front wheel bearings are the same as any old other chevy and fairly straight forward. The rear wheel bearings are the unique ones. I have not done these so I cannot comment on them.
Old Aug 5, 2006 | 07:40 AM
kb2fzq's Avatar
kb2fzq
Yeah....that was my guess, with the P-brake and all it'll probably be a ton o' fun
Somebody will chime in....thanks
Old Aug 5, 2006 | 07:42 AM
moosie982's Avatar
moosie982
The rear bearings are pressed on the rear spindle and need to be pressed apart using some special tools, it is quite an involved job. Much more involved then the average shade tree kinda guy would want to handle. Do-able yes, but not an enjoyable thing,,,,,Peace,,,Moosie
Old Aug 5, 2006 | 07:46 AM
kb2fzq's Avatar
kb2fzq
Of course, of course....that's lovely....well, then I assume I should let a pro tackle the rear bearings, huh? Hmmm...I wonder what that will cost?
(again)
Old Aug 5, 2006 | 07:54 AM
kb2fzq's Avatar
kb2fzq
I know this sounds (probably) rediculous....but is it a sound procedure?
http://www.tracyvette.com/corvetttewheelbrg.html
Old Aug 5, 2006 | 08:03 AM
w1ctc's Avatar
w1ctc
I don't see how it could get grease to the outside bearings.
Old Aug 5, 2006 | 08:22 AM
Twin_Turbo's Avatar
Twin_Turbo
The grease tool is an excellent way of getting dirt in your bearings.
When your rear bearings need grease they're probably bad and need replacing
Old Aug 5, 2006 | 08:30 AM
revitup's Avatar
revitup
The rear wheel bearing greasing tool is carried by most of the major vette parts suppliers and works great. It only gets the inner bearings though. Definately get one and do it especially if you're disconnecting halfshafts for any other reason.
Old Aug 5, 2006 | 09:43 AM
jdmick's Avatar
jdmick
That's hard to say. I sent mine off to Bairs. They charge $150 a side if your core is good. Bubba had messed with mine and made them a slip fit so I got to add another $100+ to each side. I'm glad I did it though.
Old Aug 5, 2006 | 09:53 AM
Ganey's Avatar
Ganey
The rear is unique.
The tool is like the Chevy tool for the job, J-24488.
It's better to disassemble considering the age of the cars.
Old Aug 5, 2006 | 10:45 AM
big_G's Avatar
big_G
Originally Posted by Twin_Turbo
The grease tool is an aexcellent way of getting dirt in your bearings.
There is only one way to do this job correctly. New bearings, seals and grease. If there are no symptoms, leave them alone. they will let you know when it's time for service. That said, nothing wrong with a little P/M (preventive maintenance).
Old Aug 5, 2006 | 11:32 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
So because it can't be done perfectly, don't do anything?
Everybody who has 30 year old dried out grease needs a total rebuild at a shop for $2500?
Thats why people are ****canning these cars in droves. I could buy a new car for the cost of having my car professionally maintained.
Actually considering a Mustang or Saturn Sky because i'm getting sick of all the work. And the wife hates my car and doesn't want to ride in it.. I don't blame her.
Old Aug 5, 2006 | 11:58 AM
big_G's Avatar
big_G
No. Not the point. If not done correctly, it may make things worse. At my shop, rear bearing services for both rears is about $600.00 out the door. Not $2,500. Your right about one thing though...some people should only buy new cars, as the responsibility to keep up a classic like the 'Vette isn't cheap, especially if you don't work on them yourself. Keeping up any 30+ year old car will cost something.
Old Aug 5, 2006 | 12:05 PM
turtlevette
if you have dry caked up grease in your bearings whats the harm in trying to force in some new?. If they're squeaking you will definietly ruin them if you keep driving. Not a 100,000 mile solution but maybe a 5 or 10k mile band aid. A lot of these guys only put a couple thousand miles per year. Buys them a couple of years to save some money to bring to your shop.
I bet some shops will try to nail you for $2500. I hear horror storys of guys here being taken all the time.
Old Aug 5, 2006 | 12:16 PM
Twin_Turbo's Avatar
Twin_Turbo
All cars need maintainance and wheel bearings are part of it. If you don't want to do maintainance don't drive the car, if you can't afford it, sell the car or learn to DIY. It's not that bad a job at all. No amount of grease is going to fix worn wheel bearings and doing nothing about it will ruin your axles making it even more costly.
Old Aug 5, 2006 | 12:18 PM
big_G's Avatar
big_G
The greasing tool mentioned in a previous post does nothing for the outer bearing. If too much grease is pumped in, the outer seal will pop out, and now you're in bigger trouble. If the bearings are squeaking, they are already toast. Not doing it correctly is like putting a band-aid over an already infected wound. I'm not trying to rag on you, but I make my living by doing things right. I don't want my customers hurt, or do unessesary damage to the 'Vette down the road. If they can't afford to fix it correctly, I advise them to park it until they can. JMHO
To Greasing wheel bearings?
Old Aug 5, 2006 | 12:57 PM
75 Hot One's Avatar
75 Hot One
Probably best to do the job yourself. Then you know it's done right. 2nd best is to have it done by a Corvette specialty shop. I had mine done by a Chevy dealer a number of years ago and they screwed the job up. They rotated the rear rotors from their correct position which caused runout which caused the brake shoes to squeak. They told me the rear wheels were crooked and I needed new wheels. I'll never take the car back to a dealer.
Old Aug 5, 2006 | 01:19 PM
turtlevette
Rag on me all you want. My experience is that it helped the bearings last a few more years and i kept driving to work 20- 30 miles everyday. Just relating my experience owning this car for 26 years and driving it 400,000 miles.
I even put my jet boat in my neighorhood lake with the vette submerging the whole rear end. Bearings started squeaking a few days later and i just used the bearing greaser to pump more in. Those bearings lasted several more years before squeaking again.
These things can take more abuse than you guys think. Not everybody does everything by the book. I have been running slip fit inner and outer bearings with NO center spacer for 4 years now with no problems yet. I put a butload of miles on my car too. I took it on a 3000 mile trip to the south and two trips to Canada this summer to beat the crap out of it on a road course. I constantly check the play by doing the push at the top of the tire to check for safety.
People should drive the car and have fun with it. The reality is that people are not going to spend 10,000 bucks fixing up a car thats worth 8,000.
Good business for you but not the reality of life. When people park them as you suggest they end up rotting away.
Old Aug 5, 2006 | 02:39 PM
turtlevette
I don't agree with that either. It does something short of a complete bearing pack. If you get enough grease in the axle housing, it will slump to the bottom. When braking hard the grease gets hot and tends to become more fluid working its way into the outer bearing.
How long you been a corvette mechanic?
I've been one for 26 years.
