IR Temp Guns owners...
Old Aug 5, 2006 | 09:55 PM
Jack71's Avatar
Jack71
Default IR Temp Guns owners...
Now that I have an IR gun, I'm going to shoot the temperature of every..exposed..surface of my car and monitor changes!!
These are pretty cool gadgets.
Does anybody know normal operating temps for headers? Mine are coming in around 350 degrees.
Also, what is normal for exhaust gases? Can you identify a lean/rich condition using temp alone?
Old Aug 5, 2006 | 10:00 PM
SmokinBBC's Avatar
SmokinBBC
I have one of those gadgets....my stock BB manifolds run about 380.
Old Aug 5, 2006 | 10:52 PM
GUSTO14's Avatar
GUSTO14
Jack, yes they are...
And yes you can tell a rich cylinder because it will be cooler that the rest and a lean one will be hotter. Since minor variations will occur normally, I would average the temps and if you have one that is noticably higher (or lower) you might investigate further.
These are a great tool to verify the correct air pressure to run in your tires as well. Take the car for a nice drive to ensure the tires are warmed up and stop the car in a place where you can stop in as straight a line as possible. Jump out and take at least three temps across the face of the tire. If all three temps are the same you are running the correct pressure. If the outside edges are cooler than the center, you have too much air in them. If they are warmer there is too little air. I adjust the air a couple pounds at a time until temps are even. The reason you want to stop in as straight a line as possible is so you don't skew the readings by having the tires scrub as you come to a stop.
Have fun with your new toy... I sure have... GUSTO
To IR Temp Guns owners...
