Clearance 454
Old Aug 6, 2006 | 11:24 AM
DARROW's Avatar
DARROW
Default Clearance 454
How much clearance should there be from the back of thr alt to the valve cover? Mine does not line up with the main pullys, how do I tell if It is the right one.
Old Aug 6, 2006 | 11:28 AM
gator79's Avatar
gator79
not sure on the clearance mine is not reinstalled yet. I had the same problem. my lower mounting bracket was bent
Old Aug 6, 2006 | 06:22 PM
DARROW's Avatar
DARROW
Default alt
well the breaket looks stright I think that the alt or the pully is not right.
I just installed a alum rad had every thing off and most were off befor and orig parts were not reinstalled.... the car set for about 10 years and thats not good. I have everthing(almost) on this car eather repaired or replaced and now It is starting to look and run good. I had broken studs on the rear wheels that led to a a arm rebuild the car never had the revits drilled out of the wheels and the disks look new so the milage may be right but there is or was a lot of things not working
and the engine has been opened up in the past new intake gaskets shows that and the eng info on the front block is machined off. the person I got it from is dying of cancer I bought it from his grand son
there was a 74 harly sitting next to it with 408 miles and the eng was froze probley from sitting well enough about my car what are you doing to your car.
Old Aug 6, 2006 | 07:34 PM
gator79's Avatar
gator79
well I took down this far
and this is where it is today
it is a complete frame off and I have replaced way more than I ever planned on. it will be basicly a brand new 71 when it is done.
this is what Bubba had done to my lower bracket
Old Aug 6, 2006 | 08:43 PM
DARROW's Avatar
DARROW
well I guess that about as far as you can go but it will be nice having A new car. how long have you been working on It?
Old Aug 6, 2006 | 10:41 PM
jerrylee's Avatar
jerrylee
Mine is actually flush up against it.....we had the same trouble hooking it up...That was actually the toughest part of the whole rebuild believe it or not....
Old Aug 7, 2006 | 12:01 AM
gator79's Avatar
gator79
8 months so far
To Clearance 454
