Engine Block drain Plug??????
Old Aug 6, 2006 | 09:58 PM
Richard Cooper's Avatar
Richard Cooper
Default Engine Block drain Plug??????
Can someone tell me where the engine drain plug is on my 81 small block? Thanks. I've looked everywhere but behind the starter.
Old Aug 6, 2006 | 10:09 PM
a1sensei's Avatar
a1sensei
Just went out and looked at my 81. It's about as far back as where where the oil pan goes from shallow to deep, on the block just above the oil pan. Your exhaust may be hiding it. God bless, Sensei
Old Aug 6, 2006 | 10:15 PM
noonie's Avatar
noonie
Glad you are interestd in it, an often overlooked item.
They can be very hard to loosen at times. Replace with a brass hex head if necesaary and use them to flush. One on each side of block.
Old Aug 6, 2006 | 11:57 PM
fauxrs2's Avatar
fauxrs2
They can also be replaced with brass radiator petcocks
Old Aug 7, 2006 | 12:49 AM
Richard Cooper
Thank you all very much. I'm removing my engine and want to drain the block. This is a big help. Take care and thanks again.
Old Aug 7, 2006 | 07:43 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
there are two drain plugs on either side of the block located in the middle of the block just behind the engine mounts, these will allow you to drain all of the coolant from the block.
they are small, 1/4 inch square headed bolts or close to that as i reacall.
cheers tim
To Engine Block drain Plug??????
