Lemans Gas Cap Removal
Old Aug 7, 2006 | 01:47 PM
jberman's Avatar
jberman
Default Lemans Gas Cap Removal
This is my first question to this forum. The info on the forum has helped immensely!
I have a Lemans style gas cap on my 1974 coupe. It's pitted and simply awful. I've found a replacement, but someone (bubba?) used solder to fix the cap to it's sleeve after it was screwed down. Any ideas on how to remove this solder from the inside of the gas filler area would be appreciated. I'm afraid to use a soldering gun...boom!!!
Thanks.
Old Aug 7, 2006 | 01:49 PM
SIXFOOTER's Avatar
SIXFOOTER
Can you post a pic? Can't quite picture what you have there
Old Aug 7, 2006 | 02:23 PM
jberman's Avatar
jberman
Default Gas cap removal
Here is the best picture I currently have. The cap flips up and the original filler cap is underneath. The solder is on the threads of the lemans cap on the inside, connecting it to the flange on the rear deck of the car. You can see them once the cap is opened./Users/admin/Desktop/74 vette cap.jpg
Hope this picture posted properly...first time. Thanks.
Old Aug 7, 2006 | 04:02 PM
Bob Onit's Avatar
Bob Onit
Sorry but your trying to link to a pic that is on your desktop...
You need to upload it to a server on the net
Photobucket is a good free host
http://photobucket.com/
Old Aug 7, 2006 | 04:10 PM
kdf1986's Avatar
kdf1986
Hello,
Safety first OK.
Drive the car if it is in that state until you have used up most of your gas. Then you can drain the remainer of gas into a suitable container to hold.
Leave the cap open to vent and dry the system.
Then you can start with the removal process.
If the gas cap is welded or soldered on, then that may be the method that is needed to remove it.
last resort would be a new gas tank possibly.
kdf
Old Aug 7, 2006 | 08:25 PM
TheMongoose's Avatar
TheMongoose
Originally Posted by kdf1986
Hello,
Safety first OK.
kdf
Have you seen an "Empty" gas tank near a match or spark? Even when they are completely empty they will pop when you get a torch near them. This is not a recommended action. You can still lose your eyebrows.
Old Aug 7, 2006 | 09:06 PM
kdf1986's Avatar
kdf1986
You are probably right. Thats one thing that I am always afraid of is getting gas on something, or having a leak someplace.
Trying to replace the gas cap or filler with it on the car really seems risky. Whats your advice to that. Taking out the gas tank altogether?
Thanks for adding your input on this.
kdf
Old Aug 7, 2006 | 11:49 PM
jberman's Avatar
jberman
Default Thanks and picture
Thanks for the replies so far... and to you, Bob for the photo advice...
Below is a better picture of the cap - top and bottom sections.
The bottom section screws into the flange. Unfortunately, the flange and bottom part of the cap is painted the same color as the car - even the screws holding the flange in are painted. Removing the flange may chip the paint. The material holding the bottom part of the cap to the flange definitely has solder on the threads. I was thinking that there may be some chemical that can dissolve or loosen the solder. Or, is there a tool I can use to drive out the pin holding the top part of the cap to the bottom... I would need to be very careful as the area directly around the pin is painted. I guess if all else fails, I'll have to remove the gas tank and use heat. Thanks again.
Old Aug 8, 2006 | 01:07 AM
Bob Onit's Avatar
Bob Onit
Your welcome
Now you can go nuts and upload a ton of pics......... we love pics here
Old Aug 8, 2006 | 04:32 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
How about taking a picutre to show us where exactly it is soldered?
Old Aug 8, 2006 | 05:09 AM
sam74c3's Avatar
sam74c3
Completley drain your tank. Then, refill it with water to push out fumes and air needed to make it explode. Melt the solder with a propane torch or whatever. Drain the water,and refill the tank with fresh gas. If ANY water was remaining in the tank, add one bottle of rubbing alcohol(full tank only)
Old Aug 8, 2006 | 07:58 AM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
This is one for a hundred bucks you take it to a P_R_O_F_E_S_S_I_O_N_A_L_ unless you are really comfortable, don't risk blowy upy things............
Old Aug 8, 2006 | 10:26 AM
Todbo's Avatar
Todbo
should be able to tape the area around the cap and use a punch to knock out the pin , and just replace the cap , maybe?
Old Aug 8, 2006 | 01:56 PM
1Z87L8's Avatar
1Z87L8
take a drift and knock the roll pin out similar
to the gas caps i had on my old early 70s hondas
replaced a couple that way.
To Lemans Gas Cap Removal
