knocking sound.......scary
Old Aug 8, 2006 | 01:58 PM
81cali's Avatar
81cali
Default knocking sound.......scary
I just brought the car back from the muffler shop and when we started it, there was this loud knocking sound that goes with the revolution of the motor. What could it be??? We just pu this motor together and has beeen running it for 3 consecutive days with no problem other than the loud open headers. Any possibilities where the sound is coming from?? Before we take the motor out AGAIN................. I was told to take the oil pan down and check the connecting rods.
Old Aug 8, 2006 | 02:00 PM
pws69's Avatar
pws69
Just a wild guess, but since you just had exhaust work done, is there any chance they dented the flywheel cover (bolts to the bottom of the bellhousing) such that it's hitting the flywheel/clutch??
Old Aug 8, 2006 | 02:13 PM
81cali's Avatar
81cali
We just took the cover off to find out if the flywheel bolts are tight. Could this cause a knocking sound???
Old Aug 8, 2006 | 02:20 PM
81cali's Avatar
81cali
We tried to turn the motor manually and it's tight as hell. Any idea why it would seize after running about a total of 1 to 2 hours.
Old Aug 8, 2006 | 02:21 PM
big_G's Avatar
big_G
With the spark plugs in, it will be hard to turn. Pull them and re-check. Is this a stroker motor?
Old Aug 8, 2006 | 02:25 PM
81cali's Avatar
81cali
350 vortec motor. when we were setting the timing, it was tough but could be turned. Now, we tried it with a breaker bar and the motor won't turn. instead, the bolt was starting to tighten more. I also tried to crank it and the starter can't turn it.
Old Aug 8, 2006 | 02:45 PM
big_G's Avatar
big_G
Probably best to pull the pan and check the rod bearings. They should move side-to side little.
Old Aug 8, 2006 | 02:57 PM
rihwoods's Avatar
rihwoods
Wonder if all that fuel dumping from carb affected cylinders...??
Fingers crossed for ya...
Rich
Old Aug 8, 2006 | 03:10 PM
81cali's Avatar
81cali
ok, we'll be checking all that. But what really scares me is, why did the motor seize???????? feel like hanging myself.
Old Aug 8, 2006 | 03:16 PM
rihwoods's Avatar
rihwoods
Only engine I screwed up that I built was a VW engine I pumped up..I set the thrust bearing to tight on the crank...I started it,drove only two blocks and the sucker seized....spec was .005" and I had ziltch..
Hope yours is something simpler....
Rich
Old Aug 8, 2006 | 03:39 PM
81cali's Avatar
81cali
Hey Rich,
we took the pan down and there was a lot of fuel mixed in with the oil. Yesterday, i was having problems with the regulator and so what i did was connected the pump straight to the carb, bypassing the regulator while i figure oput how to adjust the pressure. what happened is that the pump was pumping too much gas for it to burn.... . what do i do now, change all the bearings again. is there an easier fix to this?
Old Aug 8, 2006 | 03:52 PM
bahamasair's Avatar
bahamasair
Hopefully the reason it wont turn over is that the cylinders are full of fuel. take out the spark plugs and try turn the motor over by hand. im betting fuel will spray out everywhere. Hopefully you didnt damage the main bearings with the lack of lubrication the gas in the oil would provide. I doubt you would have bent the connecting rods just trying to turn over by hand but you might want to check that too. If there was a banging sound I think it might be your main bearings. I hope Im wrong, Good luck man
Old Aug 8, 2006 | 04:04 PM
rihwoods's Avatar
rihwoods
Hey Rich,
Yes..I seen your post where you removed the regulator...Ok...here is what I suggest...and I'm just speculating at this point....
1.It is possible you seized a piston...it is also possible the thrust bearing is gone..I would pull tranny first on the outside chance a flywheel bolt broke or something...that could hang the engine up..
Have you removed a valve cover ?? You may want to pull a head..You could check to see if a piston has hit a valve..???
I'm just grabbing at straws..when I seized mine,I just pulled the engine and went from there..but that was easy on a VW...
Edit..just seen the spark plug removal suggestion...do that first..good idea..
Rich
Old Aug 8, 2006 | 05:17 PM
81cali's Avatar
81cali
getting there, having a hell of a time disconnecting the tie rods to clear the oil pan. will check the and do the spark plugs. will keep you updated
Old Aug 8, 2006 | 05:25 PM
big_G's Avatar
big_G
FYI to anyone that needs to drop the pan....remove the idler arm at the frame, still gives plenty of clearance if you don't have a pickle fork.
Old Aug 8, 2006 | 05:42 PM
81cali's Avatar
81cali
#7 connecting rod in 3 pieces........... NOW, what do I do???? I'm thinking of pulling one head out and pull the piston from the top.
Old Aug 8, 2006 | 06:01 PM
HDIronman's Avatar
HDIronman
OUCH...... If it were mine I would go through the entire motor, not just try and replace the broken rod and piston. It takes a lot of force to break a rod into three pieces, and you still don't know what caused the failure. Crank should be checked, all bearings, and the cylinder as well.
Loud headers can hide problems that you could normally discover right away. Time for a rebuild.
To knocking sound.......scary
Old Aug 8, 2006 | 06:05 PM
big_G's Avatar
big_G
Dang! Yep, tear her down and inspect everything.
dgruenke's Avatar
dgruenke
Man, I tell ya, if you didn't have bad luck, you wouldn't have any luck at all.
If the connecting rod broke, there is a chance that you dinged up the block near that cylinder. Make you check that area. Also, if you broke that rod because fuel was not allowing the piston to go to the top, there is also a chance that some of the other rods may be bent. You will need to check all of them to be safe.
I feel your pain.
Old Aug 8, 2006 | 06:24 PM
rihwoods's Avatar
rihwoods
Oh man...sorry....jerk the engine...then you can start tearing it down...no short cuts now...IMO
Rich
