What alignment Spec's are you using?
Old Aug 8, 2006 | 06:12 PM
GTR1999's Avatar
GTR1999
Default What alignment Spec's are you using?
I'll be sending out a car this week for alignment and trying a new shop. What spec's have you set your cars to for street driving, stokc, VB&P, etc?
Gary
Old Aug 8, 2006 | 06:31 PM
goinbroke's Avatar
goinbroke
Gary, I used the specs that VB&P suggests.
Old Aug 8, 2006 | 06:47 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I like the stock radial tire specs.
Old Aug 8, 2006 | 07:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Gary
I'm using new but stock configuration suspension (thanks to VanSteel) with the exception of 550# front springs with 1/2 coil cut off to match the ride height of the rear with 8" bolts.
With the ride height at 27.5" all the way around, I am using the following alignment numbers:
  • Toe: 1/8"
  • Camber: 1/2* Neg
  • Caster: 3*
Old Aug 8, 2006 | 07:29 PM
Kalway's Avatar
Kalway
Most important thing of all is to make sure they're EVEN ON BOTH SIDES. VB&P suggests 2.75 caster, but if one side can't get that high, just make them both as high as you can and keep em equal.
I went with about -0.5* camber all the way around. I put a tad of toe out on the front, about 0.15" on the front and .05" in on the back. This made my '81 handle WAY better than before. I HATED the factory suggested alignment.
Old Aug 8, 2006 | 09:53 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Same here
Old Aug 9, 2006 | 07:44 AM
GruntyPants's Avatar
GruntyPants
Will the specs that VB&P suggest work with stock suspension components or is it specific to their hardware? I'm ready to have my '69 4 wheel aligned and want to get the most out of it.
Thanks!
Old Aug 9, 2006 | 11:53 AM
markdtn's Avatar
markdtn
Thanks!
Should work on any C3.
Old Aug 9, 2006 | 03:30 PM
Kalway's Avatar
Kalway
Thanks!
Their alignment data is for the stock setup, except they note that if you have the offset a-arms that you set your caster to 4.75* positive.
Old Aug 9, 2006 | 06:05 PM
Fubba's Avatar
Fubba
Which one of the settings are you guys using from the four that VB&P lists? I'm thinking I want to do Advanced Street, but I'm not sure. Will one cause more tire wear than the other? What is the difference?
Old Aug 9, 2006 | 08:45 PM
Kalway's Avatar
Kalway
If you're using 255-60-15s, you're going to be hard put to wear them out before 30,000 miles regardless. I've got like 13,000 miles on my tires and they only have 33% treadwear, even after doing autocross. I'm actually using a setting closer to a track baseline. I need to bring my front toe in a smidgen, though. You might notice your turning radius will be a bit tighter with a different alignment, too. That or my freshly rebuilt suspension made it tighter.
Old Aug 9, 2006 | 10:03 PM
Kid Vette's Avatar
Kid Vette
Everybody seems to be in general agreement.
Old Aug 10, 2006 | 02:01 AM
Kalway's Avatar
Kalway
Great sheet but one problem. Why doesn't it say which direction the toe is pointing? in or out
Old Aug 10, 2006 | 05:43 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I don't remember ever seeing a street vehicle that was set up for toe-out...and I used to work on the database for Hunter's aligners. It's a recipie for darty handling at best. Even 0* toe often likes to wander.
Old Aug 10, 2006 | 03:10 PM
Kalway's Avatar
Kalway
Funny you mention that. My front tires are set to toe out. Doesn't seem to "darty" to me. However, I prefer it to respond quickly.
Old Aug 10, 2006 | 05:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You've said that before...and I'm still having trouble imagining it. It should be wandering every which way. Basic physics - if the front of the tire is pushed out, everything you bump with the tire should be trying to push it further out.
Old Aug 10, 2006 | 06:34 PM
SanDiegoPaul
Toe OUT is for FWD cars.
To What alignment Spec's are you using?
Old Aug 10, 2006 | 07:41 PM
Kalway's Avatar
Kalway
That's what I was thinking, however, I've still got more wear on the outside of my tires than the inside. Also, VB&P recommend 3/16" toe out for an autocross baseline. At high speeds it seems to have a more positive feel around bends and corners now, though.
Old Aug 10, 2006 | 11:17 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Most FWD cars spec for toe in. I quickly flipped through one of my old spec books, the only cars I saw with an out spec were a couple of Acuras, a few Alfa Romeos, and a couple of Fiats.
Old Aug 10, 2006 | 11:34 PM
JoeRags's Avatar
JoeRags
You trying out Val's?
Dan's a real nice guy, he'll treat you well.
