head light sync
Old Aug 8, 2006 | 11:10 PM
sjmaster's Avatar
sjmaster
Default head light sync
OK.....can't seem to find any info on this: Are the headlights supposed to open / close in unison? I would think so....but I hate to guess. My RH opens a hair late......but both seem to operate powerfully and with little noise, so I am not sure if it's worth worrying about. I did take time to lubricate.
Old Aug 8, 2006 | 11:12 PM
big_G's Avatar
big_G
No, but the are usually close.
Old Aug 8, 2006 | 11:13 PM
sjmaster's Avatar
sjmaster
Default 81 engine compartment
Does anyone have a pic of a stock 81 engine compartment to post?
My air collectors and hoses to the two air cleaner snouts are missing.
Did 81 hoods have insulation??
Thanks in advance!!
Old Aug 9, 2006 | 11:36 PM
cherrybombc3's Avatar
cherrybombc3
Mine react the same way and are also lubed well. My passenger sidw opens slightly later than the driver side. I dont worry about it much as long as they open. Mine also clunk upon fully opening, a metal to metal clunk.
Old Aug 10, 2006 | 01:44 AM
MartyW's Avatar
MartyW
Mine act exactly the same except that there is no metal clunk upon opening.
Old Aug 10, 2006 | 01:56 AM
Z-man's Avatar
Z-man
Mine have always opened one slightly after another. It's much more elegant and sophisticated to have them operate in this manner...
Old Aug 10, 2006 | 02:53 AM
Bob Onit's Avatar
Bob Onit
Mine operate the exact same way.
Hey......Just be thankful they open
Old Aug 10, 2006 | 09:36 AM
kevinator80's Avatar
kevinator80
Amen to that Brother
Old Aug 10, 2006 | 10:03 AM
bluesilver82's Avatar
bluesilver82
If they open and close, you are golden. Mine girl winks. The right hand side opens after the left hand is almost fully open and same when they are closing. I just think my car is a flirtatous little B@tch. lol
Old Aug 10, 2006 | 04:32 PM
vetteaddic's Avatar
vetteaddic
I don't know if it's true,but someone said something about the hose length .
Old Aug 10, 2006 | 06:37 PM
Driftwood's Avatar
Driftwood
Everything else being equal, the driver's side headlight is closer to the vacuum source (upstream of the other one) so I would guess that one would operate a tad quicker. Is that everyone's experience?
Old Aug 10, 2006 | 06:56 PM
ark80's Avatar
ark80
8th Gear
Mine works the same way, left first then right, however, the motor must be running before they will go down. Is this normal or a sign of a vacuum leak?
Old Aug 10, 2006 | 09:41 PM
Richieboy's Avatar
Richieboy
Thanks in advance!!
Straight from the garage downstairs....2 molded plastic pieces, 2 ducts. 81 hood has no insulation.
Old Aug 10, 2006 | 09:58 PM
MartyW's Avatar
MartyW
According to my AIM and my Haynes, the vacuum canister is supposed to hold enough vacuum to opperate the headlights once after the car has been turned off. Does not go into much detail about 'how long' after the car is off. If I try to turn off the headlight within 30 seconds of turning off the car there is enough vacuum for them to close properly. If I wait much longer the headlights will not go down. I guess I got a small vacuum leak in the vacuum canister as it slowly looses vacuum after the car is off...but all in all not a big deal to me.
Old Aug 12, 2006 | 04:47 AM
Driftwood's Avatar
Driftwood
The leak is probably not in your canister-- it's probably an actuator or an actuator relay that is leaking. They have rubber diaphragms which are typically what will eventually start to leak as they age and harden.
The canister is just a plastic tank-- less likely to develop a leak unless someone pokes a hole in it or one of the hoses is leaking at the tank fitting.
Old Aug 12, 2006 | 09:54 AM
bluthundr's Avatar
bluthundr
What do you use to lubricate them? I assume youre talking about the actuator rods.
Old Aug 12, 2006 | 10:00 AM
KENS80V's Avatar
KENS80V
The canister is made out of tin and is exactly the same as a coffee or tomato paste can. They do fail....pin holes develop in the bottom from internal moisture. They are outrageously expensive for just being a tomato paste type tin can.
To head light sync
Old Aug 12, 2006 | 11:57 AM
Z-man's Avatar
Z-man
You probably don't remember, but in the '70s, the Vette commercials on TV showed a C3 "winking" at women as they passed by. (They probably unhooked one hose to get it to do this.)
Old Oct 26, 2006 | 11:32 AM
bluthundr's Avatar
bluthundr
http://youtube.com/watch?v=c8dRF961SqQ
Old Oct 26, 2006 | 11:42 AM
genuine1980's Avatar
genuine1980
Same exact for me
