Convertible deck lid hinge removal
Old Aug 9, 2006 | 07:14 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Convertible deck lid hinge removal
Anybody ever remove the hinges for the convertible deck lid?
How did you do it?
those two upper bolts are a biotch!
Old Aug 9, 2006 | 08:53 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm sure someone's done it. Try an Archives search - the regular search function is kinda sad.
Old Aug 9, 2006 | 09:08 PM
RPOZ4Z's Avatar
RPOZ4Z
I did, aside from using a distributor wrench on one of the bolts there wasn't much else.
Old Aug 9, 2006 | 10:36 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Hmm. Seems like someone would have done that before. Maybe the AIM says how to put them in, which would be helpful. My AIM is for a non-vert year, though, so I wouldn't know.
Old Aug 9, 2006 | 10:40 PM
RPOZ4Z's Avatar
RPOZ4Z
assembly manual is no help, the hinges must have been installed before the rear deck was bonded onto the body.
Old Aug 9, 2006 | 10:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Yikes! Umm...good luck?
Old Aug 10, 2006 | 07:27 AM
RPOZ4Z's Avatar
RPOZ4Z
thanks!
I think getting them off isn't going to be as bad as putting them back on!
Old Aug 10, 2006 | 12:32 PM
Mr.Gearhead's Avatar
Mr.Gearhead
Yeah.. fun bolts...
If memory serves me correctly... I wanted to break off the back half of the car to get to these. I actually drilled a hole on each of the back panel.. near the wheel cut outs... Got up in there and pushed a real long extentsion through and then attached a socket... WORKED GREAT! Then I patched the holes.
Now you could just plug the holes with rubber plugs from Home Depot.. but glassing it was a breeze...
Old Aug 11, 2006 | 08:25 AM
RPOZ4Z's Avatar
RPOZ4Z
Originally Posted by Mr.Gearhead
Yeah.. fun bolts...
That may be a good work around!
Thanks!
Old Aug 11, 2006 | 09:35 AM
71rdster's Avatar
71rdster
I took mine off. Box end wrench, lots of patience.
Old Aug 11, 2006 | 10:03 AM
MsVetteMan's Avatar
MsVetteMan
Holes through the back is the way to go. Just cut it out and patch it up later. None of it is seen so it can be a bubba job at best. I've still gotta do this myself, though one side has already been cut. Bubba beat me to it!!
Old Aug 11, 2006 | 11:30 AM
LemansBlue68's Avatar
LemansBlue68
Yeah.. fun bolts...
I did the same--drilled holes--just large enough to slip the socket and extension through. I plugged the holes with rubber well nuts in case I ever have to get in there again. God I hope not! It's a pain to get to those bolts even with the holes. As others have said, the holes aren't readily visible so the appearance of the well nuts wasn't a big deal.
Old Aug 11, 2006 | 01:10 PM
Mr.Gearhead
Ya know... I patched the holes and sanded and everything... can't even tell. If I ever have to go back into this... I am selling the thing!!!!!
Seriously speaking... it is not that big of a Bubba deal. I used a pivot socket attachment that made if super easy with my air wrench. Be careful when putting them back in... don't want to cross thread...
Absolutely worst bolts to get out... #4 mount and cage nuts... WHAT A PITA. Good thing I did a full body off... replaced everything and decide to go the hard road... I used factory replacement rivets... watch those fingers with the air hammer and bucky bar... OUCHIE....
Old Aug 11, 2006 | 10:41 PM
RPOZ4Z's Avatar
RPOZ4Z
how do you install the factory rivets with the air hammer?
Old Aug 14, 2006 | 08:47 AM
Mr.Gearhead
I bought the factory rivets with factory washers. I also bought a bucking bar and rivet hammer than goes on the end of my air hammer gun. Put the bucking bar on the rivet head side and the hammer on the the other side with washer... The hammer smashes the rivet end to "mushroom" over the washer... and there you have it... a factory looking rivet!
Pretty easy actually. WAY better than the ol' ratchet and break pop rivets....
http://www.corvette-paragon.com/cata...4-94A6BF88CD1E
http://www.corvette-paragon.com/cata...F-ECDF8C335C91
http://www.aircraft-tool.com/shop/de....aspx?PageNo=1
http://www.rivettools.com/rivet_tools.htm
To Convertible deck lid hinge removal
