Mighty Demon Idle Feed Restrictors
Old Aug 9, 2006 | 10:05 PM
Gordonm's Avatar
Gordonm
Default Mighty Demon Idle Feed Restrictors
Got some time tonight to play with the car. I had put in .031 IFR in place of the stock .037 IFR. I started it up and it idled much better. I let it warm up and took it for a ride. I did not make it out of the street and I knew it was wrong. A quick trip arounf the neighborhood and it was bucking and felt like it was starving for fuel. Give it a little gas and it cleared up. Back to the IFRs.
Drilled them out to .033. Buttoned it back up and what a difference. Idled good, good throttle response and it cruised at 2000 to 2500 rpm a smooth a possible. I even dropped it into 5th gear and lugged it down to 1500 rpm and it was fine. Gave it some throttle and it just increased speed without a problem. Seems hard to beleive that .002 would make that much difference. I can now make it to the shop to have the collecter to exhaust pipe made with a bung to hook up the LM1 and really tune it in.
BTW I am running the timing at 22 initial with 36 total. No vacuum advance right now but I might put it to a ported port in the future. No starting problems and it runs very good this way. Idles rock solid at 900 rpm. I can go lower but why.
Old Aug 9, 2006 | 10:32 PM
TJ76's Avatar
TJ76
Way to go. You'll like it. Get that LM-1 hooked-up and you will realize alot of things about your carb. It's like opening up a can of worms.
TJ
Old Aug 9, 2006 | 10:40 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
TJ
This is what I am afraid of. Good luck with the LM-1 when you get it all installed. I am really wanting to buy one to play with also. I know you and Motorhead both have one. So, at least I know I will not be alone in this. Should be able to really get the carb where it should be. Keep us/me posted.
Old Aug 10, 2006 | 08:32 AM
Gordonm's Avatar
Gordonm
But it is a good can of worms! More performance and better mileage. How can you go wrong.
Old Aug 10, 2006 | 09:36 AM
ImBatman's Avatar
ImBatman
K guys bare with me. What is an LM-1????
Old Aug 10, 2006 | 11:14 AM
Gordonm's Avatar
Gordonm
An A/F ratio logger.
http://www.innovatemotorsports.com/products/lm1.php
To Mighty Demon Idle Feed Restrictors
