Front sway bar bolt size??
Old Aug 10, 2006 | 10:12 AM
68 NJConv 454's Avatar
68 NJConv 454
Default Front sway bar bolt size?? & Tubed Coilovers!!!!
I've snapped one of the bolts that mounts the front sway bar to the frame on my 68 vert. Then when I tried to drill it out, it won't budge.
What size are these bolts? thread size? coarse? length? I think i remember them being self-tapped at the very tip even thought the nuts are welded to the top of the frame.
I looked quickly thismorning but couldn't find the other three and I'm stopping at the hardware store during lunch for some grade 8 replacements.
Anyone know the size or a good guesstimate??
I know random...
Now that I have the bolt sizes for the sway bar (thanks to Big G and other attributing members) , i just stumbled accross the new tubed aarms and coilovers on Vansteel webside.
Check these beauties out.....
http://www.vansteel.com/index.cfm?fu...&SubGroup=1935
Old Aug 10, 2006 | 10:52 AM
Bob Onit's Avatar
Bob Onit
Sorry, I dont know the size but you could call Doc Rebuild and see if they know as they have them in their catalog.
http://docrebuild.com/dr-r-web/SUSP63E.PDF
ps: what size wrench were you using when it broke?
That should usually tell you the size of the bolt... you know ...3/8 bolt = 9 1/6 wrench ect:
You can also ask this question in the C2 forum as they have been the same since 1963
Old Aug 10, 2006 | 11:07 AM
big_G's Avatar
big_G
5/16x18 Pointed tip, not self-tapping
Old Aug 10, 2006 | 11:31 AM
68 NJConv 454
Dumb question.... i assume that is 18mm in length? correct?
Thanks Big G
Old Aug 10, 2006 | 01:01 PM
Bob Onit's Avatar
Bob Onit
Thanks Big G
I believe Big G was refering to the thread of the bolt
No mm's in American parts
Diddnt mean to step on your toes Big G...
Old Aug 10, 2006 | 01:03 PM
big_G's Avatar
big_G
Thanks Big G
5/16 inch diameter, 18 threads per inch.
Old Aug 10, 2006 | 02:56 PM
68 NJConv 454
See original post for tubed coilover link.
They look sweeeet!
Anyone have these installed yet? I wanna see some pics to drool over.
To Front sway bar bolt size??
