The car: 1980 corvette with 4-speed.
The problem: If I park the car, leave the transmission in neutral
and then roll the car backward with the engine off.
The next time I try and start the car, I cannot get the car in gear with
the clutch fully depressed. Today, I had this problem and was able
to only put it in reverse with the engine off. But then when
I tried to start the car it moved backwards by the power of the
starter even with the clutch fully engaged. I immediately turned the starter off and then was able to put the car in any gear and the car shifted normally.
What is the problem with the clutch?
The reason for rolling the car with engine off is to move it close to
another car.
Inspect all the clutch linkage. The adjustment part that's on the end of the clutch pedal rod (that's probably not the name of it) could be wore out. You may have one of the springs shot on the linkage. The clutch pivot ball could be bent also.
It just sounds like the clutch isn't fully dis-engaging. Although if the power of the starter is causing it to move, I'm surprised you can drive it and shift it. On my '69 you can see the adjustment under the hood, just under the master cylinder. Adjusting the nut further out (toward the front of the car) should move the release point of the clutch further away from the floor, and to a point of complete release.
With that said you may have some bent fingers on your pressure plate and actually have a problem. If the adjustment doesn't work, it may be time to take it apart.
Thanks for your replies. I should have added in my post that the
problem seems to occur when the car is not driven for several months.
So maybe moving the car when it is in neutral has nothing to do with
the problem, but that the clutch plates are actually locking together.
Is that possible and does it mean that fingers on the release plate
are bent?
The clutch disc can rust and or stick to the flywheel and keep it from disengaging if it is left alone for a while. Usually it takes years, but depending on the clutch material and the humidity of the garage, it could be less. But once the disc has released everything should work fine.
If the above is the case, then you just need to 1)Drive the care more, or 2) Try to control the humidity in the garage or wherever you are keeping it.
I vote for more driving!
I dont know if rust has anything to do with it but
I dont know exactly what causes this but it is certainly possible as I have seen it happen more than once
Does the pedal feel different after it loosens up and you are able to shift/drive the car?
I just had this happen to my 71 vert, it has a newly resurfaced flywheel and all new dual friction clutch and pressure plate, didn't think I would ever get it to release. I blocked the wheels , bumping the starter in first than reverse no go, finally realized I needed to put in fourth gear, and bumped the starter and it came loose. The car had been setting for around a month and it had been really humid. At one point I thought I was going to have to pull the tranny.
