Compression test result questions
Old Sep 7, 2001 | 03:27 AM
BAD-L88's Avatar
BAD-L88
Default Compression test result questions
Does anyone know a reference book for these results? I know it's important that they be within 10% of each other but I didn't know they could be this high. It is an L-88 motor, I believe the compression ratio is 12:1 or 12.5:1.
1 212
2 220
3 218
4 220
5 216
6 210
7 214
8 208
Old Sep 7, 2001 | 09:10 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Compression test result questions (BAD-L88)
They look good to me.
The pressure is a function of 2 things. The compression ratio and the camshaft. A long duration, high overlap camshaft will create lower cylinder pressures during a compression test simply because the valves are staying open longer and are letting some air out on the compression stroke with the low crankig speeds.
I think you'll find that many others here have high pressures like that too. But everything looks good so far.
Dave
Old Sep 7, 2001 | 09:11 AM
norvalwilhelm's Avatar
norvalwilhelm
They look good. My 11 1/4 motor was 180-190. The cam has alot to do with the cranking compression. I usually do leak down tests.
Norval
Old Sep 7, 2001 | 04:00 PM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
That is a lot of cylinder pressure… I would run a racing fuel mix.
Old Sep 7, 2001 | 04:18 PM
nunus79's Avatar
nunus79
Healthy. Very healthy!!
In David Vizards book titled something like Max Performance Build for Small Block Chevys on a Budget, he gets into cranking compression readings and ranges. He says 200 is good street numbers and 220 is good street/strip numbers. Do you run on pump gas?
Old Sep 7, 2001 | 07:39 PM
BAD-L88's Avatar
BAD-L88
Default Re: Compression test result questions (nunus79)
Thanks guys, that's a relief to hear.
I am running on CAM 2, 110 Octane, the purple stuff.
To Compression test result questions
