Ram Horns vs. Headers
Old Aug 12, 2006 | 08:59 PM
koni9's Avatar
koni9
Default Ram Horns vs. Headers
What are some of the pro's and cons about changing from ram horns to headers?
What will you have to leave off your motor when changing from ram horms to headers?
Old Aug 12, 2006 | 09:53 PM
big_G's Avatar
big_G
Headers: Pros: Power increase (depends on your engine)
Looks good when ceramic coated
Cons: Plugs a little harder to get at
They cost money
Under hood temps higher
Reduced ground clearance
Reduced clearance for starter motor and oil filter (in
some cases)
A little louder under the hood and exhaust
You can keep all your accessories, like a/c, p/s, etc.
Old Aug 12, 2006 | 09:55 PM
GaryS's Avatar
GaryS
There has been a fair amount of discussion here and on other boards suggesting that the rams horn manifolds are actually very efficient. In my book, keeping them solves ALL of the issues of how to mount accesories and such.
Gary
Old Aug 12, 2006 | 11:41 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Headers are cool, but unless you foot is flat to the floor and you need that extra 20 HP there is no advantage performance wise.
If you want then cause they look cool thats fine too.
Old Aug 13, 2006 | 06:31 AM
kb2fzq's Avatar
kb2fzq
I have to honorably disagree....after the headers install and 2 1/2" pipe opening to the DynoMax muffs, there was a more then noticable increase in acceleration....just my 2 cents
Old Aug 13, 2006 | 06:41 AM
Bob Onit's Avatar
Bob Onit
Cons: Hot feet
Even hotter than stock manifolds
Cooks some starter motors
Had Headers on my first 73'.... never again
Old Aug 13, 2006 | 07:10 AM
Fevre's Avatar
Fevre
My under hood temp went down and power went up after installing Dynomax ceramic coated headers
Old Aug 13, 2006 | 07:31 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Was that because of the headers or the 2.5" pipe?
Old Aug 13, 2006 | 11:24 AM
Corvette Charlie's Avatar
Corvette Charlie
I reciently put 10 thousand in the engine bay of my 73 and when it came time to address the exhaust end of things I did a lot of home work. What I ended up with were a pair of 2.5 inch stock rams horns off a 66 327 vette. I ground off the alt bracket on the driver side and sent them both to jet hot. They sent them out and got them extrude honed (ported and polished) and then coated them a flat grey color and flow bench tested them. This was not an inexpensive process, but it was important for me to retain the stock look, and yet get the performance benifits of headers without the headaches and that is just what I achieved.
To Ram Horns vs. Headers
