carb gasket?
Old Aug 12, 2006 | 10:47 PM
onaqwst's Avatar
onaqwst
Default carb gasket?
i have an older holley that i'm putting on my edel performer 2101 intake... has the split in the middle (dual plane?)..... i got a gasket from murrays and it doesnt have the middle thin gasket portion......did they give me the wrong one?.....
b
Old Aug 12, 2006 | 11:17 PM
onaqwst's Avatar
onaqwst
i think they gave me a plate?... it's about 1/4" thick..... is there a gasket also..... 1 or 2?
Old Aug 12, 2006 | 11:30 PM
olescarb's Avatar
olescarb
the plate is to allow a non q-jet to seal on the manifold, you should use a (thin) open gasket on each side of the plate.
henry @ oles carb
Old Aug 12, 2006 | 11:33 PM
rihwoods's Avatar
rihwoods
Is this 1/4" spacer a phenolic one ? Of course there should be gaskets...but I run a Holley 750 on an old school Eldelbrock intake with just gaskets and a heat shield...which...gives more hood clearance and no fuel boiling issues..."no spacer"
Old Aug 12, 2006 | 11:37 PM
onaqwst's Avatar
onaqwst
hmmm.... the spacer is a dark hard plastic like material....... i'll double check it all tomorrow in the light to see exactly what is going on..... i could have swore that my carb bolted up nicely without the spacer... maybe i'm wrong
b
Old Aug 12, 2006 | 11:46 PM
rihwoods's Avatar
rihwoods
b
You are not wrong..often those thick spacers are used to prevent fuel in carb from "boiling" on very hot days...my solution was a GM heat shield because I did not have room for a spacer...(my wing nut on the air cleaner clears hood by 3/4")....so I had no choice but to use the thin heat shield....
Rich
Old Aug 13, 2006 | 05:40 AM
Bob Onit's Avatar
Bob Onit
When I run a Holley on my 73' with the Edelbrock 2101
I must use the phenolic spacer ...the one I have is about 1/2" thick and I use a gasket on either side (2 gaskets, top and bottom) of the spacer
The spacer I use has 4 holes, one for each venturi.
I suppose you could use the wide open spacer (no holes) but I have never tried it.
I do know that without the phenolic riser I did have problems with performance.
As soon as I added the riser the carb worked great.
Good luck
To carb gasket?
