From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by c69vete
What happens to the standard point ignition if you are running 12 volts into it instead of the resistor wire voltage of 9 volts?
Nine volts is a myth. (There's been several threads regarding this.) The resistor wire limits the CURRENT into the coil, it does not modify the system voltage from 12 down to 9.
Shafrs3 is correct. The additional current will erode the points.
Keep in mind that you may also burn up the coil (from excess CURRENT, and the resulting higher power dissipation).
