I think the A/C radiators are really two radiators in one. A small section of the radiator is really a second separate radiator for the A/C. If you don't have A/C, you would be wasting a good chunk of cooling capacity by getting an A/C radiator...
The difference was usually 3 row vs. 4 row, but not always. Generally when you have the A/C on the condensor will get hot and the condensor sits in front of the radiator. A 4 row radiator can remove more heat than a 3 row so the idea is to have better cooling capacity for when you have something that's going to make the air in front of the radiator even warmer. If you replace your radiator with a new aluminum "race" radiator you shouldn't have any problems with overheating while running the A/C.
The radiator doesn't have anything to do with the A/C. The A/C condensor is bolted to the front of the radiator support. Auto cars have a transmission cooler in the stock radiator, though.
Automatic transmission cars do have a cooler built into the radiator. And the weather stripping pieces only surround the radiator on the top, bottom and drivers side. On the passenger side of the radiator there should be no weather stripping. That is because there is a vented opening where air is allowed to pass thru in order to cool the built in transmission cooler.
Ahhh...that's what that is. I had always thought it was for the A/C. Hmmm...it seems that's a long way to run hoses from the transmission...
