Vacuum Stuff - Need help
I guess i should go into a little background first. I have a 75 coupe. I dropped in a zz502 with an accel superram on top and a keisler tremec kit behind it. I ripped out my entire interior last year and im going to put it all together now and im having a hard time figuring out everything. i think i have most, if not all, of the wiring down. Heres where i run into trouble though - Im not familiar with the vacuum equipment on these cars. I want to get rid of anything and everything that i can. I have the killer light conversion so i dont need that stuff anymore. What should i be looking for in the inside of the car to make sure i hook up, and more importantly make sure i dont hook up. I found this deal that looks like a revolver magazine (creative discription) with vacuum lines going into it. What is it?
Anyway, sorry for the lack of knowledge type post but im trying to learn things as i go. I deal a lot with newer cars, especially imports that are all electronics with none of this stuff.
As always,
Thanks guys
P.S. Where is the original backup light harness deal that i need to splice into for the backup signal on the tremec?
When I took mine apart, I made detailed drawngs of the vaccuum line routing because I'm not much good at putting a plate of spaghetti back together from memory.
Also on the vaccuum lines for headlights, wiper door etc., I detailed those too because most drawings I found were different than what I had. Most showed 2 headlight actuator relays, my '69 only had 1 with T's to both lights. I dunno, either a GM change or maybe Bubba lost the other one.
Best wiring diagram comes from fellow member Don Olson
You can Email him vetsvett2002@yahoo.com
Full Color diagram, fully laminated!
Cool, i left most of it attached but i think there were 1 or 2 lines disconnected (the car is not here at the moment). They probably go to the controls though.
