Header question
Old Aug 15, 2006 | 01:40 AM
Fstdraw's Avatar
Fstdraw
Default Header question
Putting on new ceramic coated headers next week. When I was testing fitting these, I noticed the headers (hooker comps) fit better (more room) around the spark plugs and the idler rod, but are about an inch closer to the floor of the car. Question...What should I do to the starter to keep this additional heat from frying it? Will I even have problems? Thanks for the insight.
Old Aug 15, 2006 | 02:33 AM
Les's Avatar
Les
The ceramic coating will help but you can also buy heat resistant wraps that are made specifically for starters. My local starter/alternator rebuilding shop sells them but they may also be available from Summit or Jegs.
Old Aug 15, 2006 | 11:03 AM
Fstdraw's Avatar
Fstdraw
Les- Good idea. I'll call the local starter/alt rebuilder and get something from them, or order from Jegs. Thanks
Old Aug 15, 2006 | 12:32 PM
Little Mouse's Avatar
Little Mouse
You could wrap the header where it is close to the starter.
Old Aug 15, 2006 | 02:10 PM
Kalway's Avatar
Kalway
I think my starter is actually the original starter and I've had long tube headers for probably over 6 months without any "heatsoak" issues. 90% of the time I go to start my vette it only takes like a half to one and a half cranks to get started anyways.
Old Aug 16, 2006 | 12:30 AM
Fstdraw's Avatar
Fstdraw
Thats good news to me Kalway, the fewer problems the better.
Good idea Little Mouse, I will diff. do the cloth wrap.
Old Aug 16, 2006 | 04:12 AM
Les's Avatar
Les
Be careful with the header wrap- it can deteriorate the metal for the tubes & lead to early failure. I've not only read that elsewhere but have seen it referred to by members here.
To Header question
