T-Arm HELP
Old Aug 15, 2006 | 09:17 AM
78anniversary's Avatar
78anniversary
Default T-Arm HELP
I am going to be removing my T - Arms soon. I was very glad to find the bolts were not frozen so no sawzall or torch will be needed. But how in the world do you get your hand back there to get them out or better yet put back in???? The brake line bracket is right in the way blocking the opening just enough so you can't get you hand in there.
Any suggestions are greatly appreciated.
Old Aug 15, 2006 | 09:29 AM
BerniesVette's Avatar
BerniesVette
I used needle nose pliers to start the bolts.
Old Aug 15, 2006 | 11:52 AM
revitup's Avatar
revitup
It's tight but you can get enough of your hand in there to get it. Getting them out is a piece of cake compared to getting them back in. The LH one is the toughest for some reason. I put a piece of safety wire around it so I wouldn't have to spend 10 minutes retrieving from wherever every time I dropped it. Which was a lot. Suspend the TA from the frame with safety wire in the final bolted position so you only have to maneuver it slightly to get the holes to line up.
Old Aug 15, 2006 | 12:03 PM
Tankers's Avatar
Tankers
Pull the body off the frame I used some strong wax string that I put through the frame, T-arm then attached to the hole in the end of the bolt. When everything was lined up I pulled on the string, this helped get the bolt started and was easier to find each time it fell.
Old Aug 15, 2006 | 02:21 PM
68sbShark's Avatar
68sbShark
Thats what I did. I used a few choice words as well.
Quick tip: Test fit the bolts in the TA before you put the TA in. You want to make sure that the sleeve in the bushing is still round and did not get distorted when you staked it.
~Rich
Old Aug 15, 2006 | 02:31 PM
djcwardog's Avatar
djcwardog
I had a helper hold the t-arm in aligned position and I just ran the bolts straight through with no hassle. The shims stay put thanks to the cotter pin that holds them in. I held them in alignment as I fed the bolt through...
Old Aug 15, 2006 | 04:13 PM
rexx78's Avatar
rexx78
Use fishing line or lock wire. Pass it through the cotter pin hole on the bolt, then through the frame, TA, and frame again. Works slick.
Old Aug 16, 2006 | 06:59 AM
silver 76's Avatar
silver 76
I taped the bolt to a paint mixer stick to get it started into the hole much time and beer.
Old Aug 16, 2006 | 08:59 AM
GruntyPants's Avatar
GruntyPants
I was in the same boat a month ago, but some needle-nosed vice-grips, and some small dabs of RTV to hold the washers to the TA's worked very well. I was able to locate the TA into the pocket and keep it in place with a jack stand and get everything lined up and bolted in by myself. It only seems impossible, once you do it a couple times it becomes much easier.
To T-Arm HELP
