Gone LED.
Old Aug 16, 2006 | 07:10 PM
Durango_Boy's Avatar
Durango_Boy
Default Gone LED.
If anyone has been wanting to switch their car's bulb system over to LED, I would suggest this website.
www.Superbrightleds.com
I just ordered every bulb in my Vette, save headlights, for $130 after shipping. They have a bulbs for everything. Dash, floor, backup, marker...everything. Check them out.
Old Aug 16, 2006 | 07:45 PM
gator79's Avatar
gator79
let us know how they work.
Old Aug 16, 2006 | 09:53 PM
HighHeat303's Avatar
HighHeat303
Default I've been interested in that.
Did u stick with the stock color or did u change? let us know what it looks like when done.
Old Aug 17, 2006 | 09:50 AM
Durango_Boy
I went with stock colors. Behind the red lenses are 24count red LEDs. Amber for the fronts, whites for courtacy lamps, rear plate bulb, center console bulb, gauge bulbs and such. Green for signals, blue for high beam indicator and so on. I picked bulb color based on teh color of the filter. Since the bulbs have 'True' color it will only help that they are the same color as the filtes. I will have to buy HD Flashers for the signal and hazard relays but that's something I've learned is good for anyone's car no matter what bulbs you run.
Old Aug 17, 2006 | 10:46 AM
PatsLs1vette's Avatar
PatsLs1vette
Matt let us now how they look and some pics of them if you can when done.
Old Aug 17, 2006 | 12:40 PM
Durango_Boy
Absolutely. I will actually start a new thread, with a full write up on what I did complete with pics. I'm hoping there will be no problems. The site is a little hard to order from because the bulb style numbers are changed. They try to help you with a conversion chart, and a list of all the stock bulbs that are in whatever car you are working on. It took me an hour to order them, but it was worth it. They should be here in a few days, and I can start playing with them.
Old Aug 17, 2006 | 02:38 PM
68/70Vette's Avatar
68/70Vette
Some LEDS can be really bright. Are the bulbs, particularly the instrument gauge lights the correct brightness? Also, your current instrument lamp dimmer is a reostat (coiled resistance wire) built into the headlamp switch. Will the dimmer work?
One good thing about LEDS is that should last a lot longer than a filament bulb and also they don't use very much power and hence make a lot less heat.
Old Aug 17, 2006 | 02:45 PM
Durango_Boy
Yes, all these bulbs are designed for automotive use. They will dim just fine with the factory dimmer switch. Also, they are designed to spread light better than in the past.
The 1157 lights I got for the tail/brake/signal lamps are dual intensity, so they will work just like a bi-filiment bulb. Cool huh?
Old Aug 17, 2006 | 05:08 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The LED taillights that AutoZone has for sale work the same way.
Did they have the correct weird bulb for the HVAC control light? It's way up on top of the center console and has a lens on it so that light will actually hit the controls.
Old Aug 17, 2006 | 05:22 PM
Durango_Boy
The Autozone bulbs are twice the cost, otherwise, yes, they work just fine.
The spotlight bulb was there as well...it's a simple matter of finding the right mm size base.
Old Aug 17, 2006 | 05:48 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's a good deal on the taillights.
Now I'm sorely tempted to switch my lights over to LED...there goes more money...lol.
Old Aug 17, 2006 | 06:36 PM
Durango_Boy
Correction...money well spent...
Old Aug 17, 2006 | 06:49 PM
supervette2's Avatar
supervette2
Sounds really cool im curious to see how this turns out
Old Aug 17, 2006 | 07:03 PM
Durango_Boy
Don't worry, I'll post it all up for eveyone to see.
Old Aug 18, 2006 | 03:44 PM
Durango_Boy
The box - O - LEDs came today. I will open it, inspect them, and do some fun testing later tonight. I'll get pics and everything for this initial test phase.
Old Aug 18, 2006 | 09:01 PM
NuclearBob's Avatar
NuclearBob
Default Superbright LEDs
I've bought bulbs from this company before at work and we were VERY pleased with the quality and prices. We use a number of these in various control panels and they seem to last forever..
Old Aug 18, 2006 | 09:12 PM
Durango_Boy
Yeah, I had my box within the end of two days. They did give me two wrong bulbs. Instead of two 1156, single contact, 12LED...I got a set of 1157 dual contact 12LED. Other than that, which they are correcting immediately...everything went smooth.
To Gone LED.
Old Oct 13, 2006 | 09:01 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Did you ever manage to get the bulbs in and how did they look?
Old Oct 13, 2006 | 11:23 PM
SIXFOOTER's Avatar
SIXFOOTER
Curious about this one myself
Old Oct 14, 2006 | 07:59 AM
rabiddawg's Avatar
rabiddawg
heres another site:
http://www.automotiveled.com/
