ride hieght
Old Aug 16, 2006 | 09:29 PM
popa's Avatar
popa
Default ride hieght
Hi everyone, I am in the process of building a 69 t top it was a 350 4speed w/air. I removed the air and dropped in a 454 AUTO. I did not replace the front springs,I think bb and sb w/ac are the same spring?? The car is 10 inches off the ground at the frame. It has 235/60 /15 now which imo looks bad because of 3 1/2 to 4 inches of space between the tire and the wheel well. I want the car to set lower yet fill the wheel opening better. A taller tire would fill the opening better, but also raise the ride hieght. How is the best yet most cost effective way to lower the car and not hurt the handling to bad. THANKS Kent in ar.
