power to manual steering conversion
Old Aug 17, 2006 | 12:26 AM
panic's Avatar
panic
Default power to manual steering conversion
hi, could i go from power to manual steering on a '77? what would be the best option and best bolt on kit? weight savings? thanks/Giu
Old Aug 17, 2006 | 01:45 AM
panchop's Avatar
panchop
I did it on my 75 and my 65. just find a manual draglink somewhere and swap it out. pretty easy.
Old Aug 17, 2006 | 03:16 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Post an ad in the "C3 Parts Wanted" section - I got a good manual steering drag link for $55 for my Jeep Box conversion.
Old Aug 17, 2006 | 07:55 AM
GTR1999's Avatar
GTR1999
You also need a manual pitman arm for the box.
Old Aug 17, 2006 | 08:46 AM
stinkray's Avatar
stinkray
And the drag link end, and the steering stabilizer/ control valve, and the bracket for the steering stabilizer/ control valve.
Old Aug 17, 2006 | 11:52 AM
panic's Avatar
panic
where could i buy a full bolt on kit to replace my power steering box? i cannot risk to make a patched work here and i'm definitely not able to put hands in the job
need a bolt on application thanks/Giu
Old Aug 17, 2006 | 01:17 PM
GTR1999's Avatar
GTR1999
The box is the same, only the center link and pitman arm are different between stock PS and manual. Aftermarket kits offer the jeep boxes or rack setups but a properly built box with good suspension parts will be 100% better then factory set box. Of course this is my opinion since I rebuild these but I'd look around before making a decision.
Old Aug 17, 2006 | 01:37 PM
Ed Blue 03's Avatar
Ed Blue 03
Converted my 73 from P/S to manual. The only thing that had to be replaced was the Centerlink and Pitman Arm. Good Luck.
Old Aug 17, 2006 | 01:53 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What's different about the pitman arm?
Old Aug 17, 2006 | 03:03 PM
Ed Blue 03's Avatar
Ed Blue 03
The bends on it are different.
Old Aug 17, 2006 | 05:06 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Hmm...anyone got the compartive dimensions for the two arms? Since I'm using a manual drag link for my Jeep Box conversion, I might as well get the Jeep arm bent to match the manual pitman arm, not the P/S arm that I have.
Old Aug 17, 2006 | 05:09 PM
panchop's Avatar
panchop
you can use the power pitman arm. it has an extra bend in it to clear the power stuff but it works fine for the manual.
To power to manual steering conversion
