Idle solenoid nut
Old Aug 17, 2006 | 12:41 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Idle solenoid nut
Does anybody know where to get the idle solenoid nut for my 73? My books don't have it or I can't find it. Vendor and part number would be great.
Thanks in advance,
Wes
Old Aug 17, 2006 | 02:50 AM
Bob Onit's Avatar
Bob Onit
Qjet?
Maybe this will help
Far right column Part #3275603
http://docrebuild.com/dr-r-web/CARB-VAC.PDF
Old Aug 17, 2006 | 03:00 PM
73, Dark Blue 454
Thanks Bob,..I called that place and Dr. Rebuild's computer differs with the catalog link you provided. The link says the nut is good on 71-76 Vettes. Their computer says 71-72. I have a 73.
Does anyone know if the idle solenoids changed from 72 to 73?
Thanks,
Wes
Old Aug 17, 2006 | 03:18 PM
Bob Onit's Avatar
Bob Onit
Thats the first time I have heard of Doc bieng off on his catalog......sorry
Does the pic of the solenoid look correct?
Old Aug 17, 2006 | 04:02 PM
mdj21's Avatar
mdj21
it's just a jam nut.
take your solenoid down to the local ACE hardware or nut and bolt store and find the one that fits.
Old Aug 17, 2006 | 11:51 PM
73, Dark Blue 454
If I went to Ace Hardware and asked for a nut to fit a 3/4" course thread, they'll trot out a big honking hunk of metal.
The correct nut is specific to the task,..very thin.
Thanks just the same,
Wes
Old Aug 18, 2006 | 07:31 AM
pws69's Avatar
pws69
Wes
If you know anyone with a lathe, you could have them cut down that "honking" nut to the size you need pretty easily.
Old Aug 18, 2006 | 07:46 AM
mdj21's Avatar
mdj21
Wes
that's because you are asking them for a nut instead of a jam nut.
read the description at doc rebuild. he refers to it as a jam nut.
a jam nut is less than half the thickness of a regular nut.
if you can not find a jam nut at ACE, any good nut and bolt supply house will have them.
hope this helps,
Mike.
Old Aug 18, 2006 | 08:27 AM
carbster09's Avatar
carbster09
Default Idle solenoid ..
I know its NOT the same as a 71. Went through that drill. Only Doc Rebuild had the right part and I searched the country.
carbster
Old Aug 18, 2006 | 12:07 PM
olescarb's Avatar
olescarb
holley part # 26-57 is a idle solenoid lock nut 7/8 - 14 threads, if this is not the size you need what thread size are you looking for?
henry @ oles carb
Old Aug 18, 2006 | 02:22 PM
mdj21's Avatar
mdj21
carbster
so what is so special about an idle solenoid jam nut for a 71?
is it an odd ball thread pitch?
how much did Doc Rebuild want for it?
To Idle solenoid nut
